Hi there
on a jetson NX (Siemens IPC520), running jetpack 5.0.2 + upgraded CUDA to 11.8, I am using docker with NVIDIA Docker toolkit v1.15.0-1.
All was running OK, and suddenly (no update done on the system, at least that I know) I am facing the following error :
sudo docker run -it --runtime nvidia --entrypoint “bash” imagetagxx:0.5
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running createContainer hook #1: exit status 1, stdout: , stderr: time=“2024-12-18T13:30:39+01:00” level=info msg=“Symlinking /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/lib/aarch64-linux-gnu/tegra/libcuda.so to libcuda.so.1.1”
time=“2024-12-18T13:30:39+01:00” level=info msg=“Symlinking /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/lib/aarch64-linux-gnu/libvulkan.so.1.3.203 to tegra/libvulkan.so.1.3.203”
time=“2024-12-18T13:30:39+01:00” level=info msg=“Symlinking /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-kms.so to libnvidia-kms.so.35.1.0”
time=“2024-12-18T13:30:39+01:00” level=info msg=“Symlinking /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-vksc-core.so to libnvidia-vksc-core.so.35.1.0”
time=“2024-12-18T13:30:39+01:00” level=info msg=“Symlinking /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json to …/…/…/lib/aarch64-linux-gnu/tegra-egl/nvidia.json”
time=“2024-12-18T13:30:39+01:00” level=error msg=“failed to create link […/…/…/lib/aarch64-linux-gnu/tegra-egl/nvidia.json /usr/share/glvnd/egl_vendor.d/10_nvidia.json]: failed to create symlink: failed to remove existing file: remove /var/lib/docker/overlay2/64804fb55c304cf300fc55a5d0d75a852bbf097098f9e1a9daecef22f58bdda0/merged/usr/share/glvnd/egl_vendor.d/10_nvidia.json: device or resource busy”: unknown.
I am able to run the image without --runtime nvidia tag
I am building the docker image on a amd/ubuntu 20.04 host machine and docker-save / scp / docker-load to/on the jetson.
any guidance? I will try to remove dockertoolkit and/or docker… in case smth on the jetson os was corrupted?
Thanks for your help
Charlie
