Failed to created hydra engine for viewport
Intel(R) Core™ i7-4790 CPU @ 3.60GHz 3.60 GHz rtx 2060
Hi I got a problem with audio2face Failed to created hydra engine for viewport,
launcher.log (266.3 KB)
omni.kit.extension.log (1004.7 KB)
omni.kit.internal.log (2.3 MB)
omni.kit.log (19.2 KB)
I install the older version cause with the latest I got a cache problem and dont show the viewport too
I am sorry to tell you but your RTX 2060 is below minimum specs. We require at least a 3070 RTX
Hi Richard I solved the problem and Im using right now audio2face with the rtx2060 goes low butt with patience I can use it, for others who got an 2060 I use the 2023.1.1 version
