Failed to display compute instances: Unknown Error
When I create the GI on A100-40G, I cant create the CI on created GI.
have the same problem, did not find root cause and solution
The original example here makes it look like the mig configuration is being modified from within a container.
While that may be possible, it may also be an “unusual” use case. I think it would be necessary for the container to have the mig-config property assigned to it. See here. I don’t have a specific recipe and none of the entries in this thread actually confirm that the goal is to configure mig from within a container. For simplicity, my suggestion would be to configure mig from bare metal or a VM, not from within a container.
For other situations, be sure that a recent driver is properly installed on the machine.
