This example is dynamically changing element.
I tested a below example.
#include <gst/gst.h>
static gchar *opt_effects = NULL;
#define DEFAULT_EFFECTS "identity,exclusion,navigationtest," \
"agingtv,videoflip,vertigotv,gaussianblur,shagadelictv,edgetv"
static GstPad *blockpad;
static GstElement *conv_before;
static GstElement *conv_after;
static GstElement *cur_effect;
static GstElement *pipeline;
static GQueue effects = G_QUEUE_INIT;
static GstPadProbeReturn
event_probe_cb (GstPad * pad, GstPadProbeInfo * info, gpointer user_data)
GMainLoop *loop = user_data;
GstElement *next;
if (GST_EVENT_TYPE (GST_PAD_PROBE_INFO_DATA (info)) != GST_EVENT_EOS)
return GST_PAD_PROBE_PASS;
gst_pad_remove_probe (pad, GST_PAD_PROBE_INFO_ID (info));
/* push current effect back into the queue */
g_queue_push_tail (&effects, gst_object_ref (cur_effect));
/* take next effect from the queue */
next = g_queue_pop_head (&effects);
if (next == NULL) {
GST_DEBUG_OBJECT (pad, "no more effects");
g_main_loop_quit (loop);
return GST_PAD_PROBE_DROP;
g_print ("Switching from '%s' to '%s'..\n", GST_OBJECT_NAME (cur_effect),
GST_OBJECT_NAME (next));
gst_element_set_state (cur_effect, GST_STATE_NULL);
/* remove unlinks automatically */
GST_DEBUG_OBJECT (pipeline, "removing %" GST_PTR_FORMAT, cur_effect);
gst_bin_remove (GST_BIN (pipeline), cur_effect);
GST_DEBUG_OBJECT (pipeline, "adding %" GST_PTR_FORMAT, next);
gst_bin_add (GST_BIN (pipeline), next);
GST_DEBUG_OBJECT (pipeline, "linking..");
gst_element_link_many (conv_before, next, conv_after, NULL);
gst_element_set_state (next, GST_STATE_PLAYING);
cur_effect = next;
GST_DEBUG_OBJECT (pipeline, "done");
pad_probe_cb (GstPad * pad, GstPadProbeInfo * info, gpointer user_data)
GstPad *srcpad, *sinkpad;
GST_DEBUG_OBJECT (pad, "pad is blocked now");
/* remove the probe first */
/* install new probe for EOS */
srcpad = gst_element_get_static_pad (cur_effect, "src");
gst_pad_add_probe (srcpad, GST_PAD_PROBE_TYPE_BLOCK |
GST_PAD_PROBE_TYPE_EVENT_DOWNSTREAM, event_probe_cb, user_data, NULL);
gst_object_unref (srcpad);
/* push EOS into the element, the probe will be fired when the
* EOS leaves the effect and it has thus drained all of its data */
sinkpad = gst_element_get_static_pad (cur_effect, "sink");
gst_pad_send_event (sinkpad, gst_event_new_eos ());
gst_object_unref (sinkpad);
return GST_PAD_PROBE_OK;
static gboolean
timeout_cb (gpointer user_data)
gst_pad_add_probe (blockpad, GST_PAD_PROBE_TYPE_BLOCK_DOWNSTREAM,
pad_probe_cb, user_data, NULL);
return TRUE;
static gboolean
bus_cb (GstBus * bus, GstMessage * msg, gpointer user_data)
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_ERROR:{
GError *err = NULL;
gchar *dbg;
gst_message_parse_error (msg, &err, &dbg);
gst_object_default_error (msg->src, err, dbg);
g_clear_error (&err);
g_free (dbg);
break;
default:
break;
return TRUE;
int
main (int argc, char **argv)
GOptionEntry options[] = {
{"effects", 'e', 0, G_OPTION_ARG_STRING, &opt_effects,
"Effects to use (comma-separated list of element names)", NULL},
{NULL}
GOptionContext *ctx;
GError *err = NULL;
GMainLoop *loop;
GstElement *src, *q1, *q2, *effect, *filter1, *filter2, *sink;
gchar **effect_names, **e;
ctx = g_option_context_new ("");
g_option_context_add_main_entries (ctx, options, NULL);
g_option_context_add_group (ctx, gst_init_get_option_group ());
if (!g_option_context_parse (ctx, &argc, &argv, &err)) {
g_print ("Error initializing: %s\n", err->message);
g_clear_error (err);
g_option_context_free (ctx);
return 1;
if (opt_effects != NULL)
effect_names = g_strsplit (opt_effects, ",", -1);
else
effect_names = g_strsplit (DEFAULT_EFFECTS, ",", -1);
for (e = effect_names; e != NULL && *e != NULL; ++e) {
GstElement *el;
el = gst_element_factory_make (*e, NULL);
if (el) {
g_print ("Adding effect '%s'\n", *e);
g_queue_push_tail (&effects, el);
pipeline = gst_pipeline_new ("pipeline");
src = gst_element_factory_make ("videotestsrc", NULL);
g_object_set (src, "is-live", TRUE, NULL);
filter1 = gst_element_factory_make ("capsfilter", NULL);
gst_util_set_object_arg (G_OBJECT (filter1), "caps",
"video/x-raw, width=320, height=240, "
"format={ I420, YV12, YUY2, UYVY, AYUV, Y41B, Y42B, "
"YVYU, Y444, v210, v216, NV12, NV21, UYVP, A420, YUV9, YVU9, IYU1 }");
q1 = gst_element_factory_make ("queue", NULL);
blockpad = gst_element_get_static_pad (q1, "src");
conv_before = gst_element_factory_make ("videoconvert", NULL);
effect = g_queue_pop_head (&effects);
cur_effect = effect;
conv_after = gst_element_factory_make ("videoconvert", NULL);
q2 = gst_element_factory_make ("queue", NULL);
filter2 = gst_element_factory_make ("capsfilter", NULL);
gst_util_set_object_arg (G_OBJECT (filter2), "caps",
"format={ RGBx, BGRx, xRGB, xBGR, RGBA, BGRA, ARGB, ABGR, RGB, BGR }");
sink = gst_element_factory_make ("ximagesink", NULL);
gst_bin_add_many (GST_BIN (pipeline), src, filter1, q1, conv_before, effect,
conv_after, q2, sink, NULL);
gst_element_link_many (src, filter1, q1, conv_before, effect, conv_after,
q2, sink, NULL);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
loop = g_main_loop_new (NULL, FALSE);
gst_bus_add_watch (GST_ELEMENT_BUS (pipeline), bus_cb, loop);
g_timeout_add_seconds (1, timeout_cb, loop);
g_main_loop_run (loop);
gst_element_set_state (pipeline, GST_STATE_NULL);
gst_object_unref (pipeline);
return 0;
It is successful.
And I changed a nvoverlaysink element from a ximagesink;(LINE. 186).
It occurred a segmentation fault or blocked below.
Adding effect 'identity'
Adding effect 'exclusion'
Adding effect 'navigationtest'
Adding effect 'agingtv'
Adding effect 'videoflip'
Adding effect 'vertigotv'
Adding effect 'gaussianblur'
Adding effect 'shagadelictv'
Adding effect 'edgetv'
Switching from 'identity0' to 'exclusion0'..
I want to know what caused the problem and how to fix it.
Environment:
Jetson TX2, Jetpack 3.2.1, Gstreamer version 1.8.3
