HuiW
1
Hi
We like to enable WDM function on L4t R32.4.3 for NX to use a 5G module.
set CONFIG_WDM=y
After compiled, cdc_wdm.ko did not be built in drivers\usb\class.
Is it normal?
However, cdc_wdm.ko is built in original config.
But 5G device did not work with this cdc_wdm.ko
Is there I missed?
Thank you for any advice,
Hi HuiW,
You have to configure it as “=m” to make it build as a .ko file. Otherwise, it will be inside Image.
We don’t have experience in 5G module. Maybe you can refer to some posts on forum first.
HuiW
4
Hi WayneWWW,
Thank you for your prompt support.
I will test it.
Thank you,
