Failed to execute sample_driveupdate
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
Judging from the following execution results, writing serve local_path="/home/nvidia/update" to /gos-a/content/cmd failed.
$ ./sample_driveupdate -d /home/nvidia/update/dumaster-metadata.json
[INFO]Client will connect to server
[INFO]Create a socket 127.0.0.1:0
[INFO]Connection to /gos-a not ready
Retrying connect to router. retries = 10
Retrying connect to router. retries = 9
[INFO]Peer is closed. Try to connect with magic word.
[INFO]Socket 0: 127.0.0.1:34270 <-> 127.0.0.1:5009, FD: 5 is connected.
[INFO]Handle 0x7f8f975a88, client request a connection
[INFO]Remote node /gos-a is connected
[INFO]CONMGR-IVC: handle Id 0x110001 P2P connection established
serveCmd=serve local_path="/home/nvidia/update"
[ERR][dulink_remote_ops.c:1414]Remote operation returned failure
Error export files to DULINK space
Failed to serve File
Dear @mayinghua,
May I know the used platform and drive release version?
Drive OS is 5.2.0.
Platform is p3479a04-t194.
Dear @mayinghua,
Could you confirm if you have flashed Devzone release on p3479?
What is Devzone release ?
On the p3479a04-t194 platform, only the virtualization configuration of QNX OS is available. I added the virtualization configuration of the Linux OS to drive-t186ref-foundation.
I have tested the sample_driveupdate on e3550_t194a platform.
The same error occurred.
Dear @mayinghua,
Devzone means, you logged in sdkmanager using developer.nvidia.com credentials and get the Drive release. It looks like you have not used Devzone release. Could you please confirm that?
I got the Drive release from sdkmanager.
I use dushell to export local files to /gos-a/dushell/files.
Execute the following command:
echo “deploy metadata=/gos-a/dushell/files/dumaster-metadata.json content_root=/gos-a/dushell/files” > /master/cmd
The tii plugin execution failed:
[INFO]Scheduler state: INSTALLING
[INFO]State written to listener 0 from element /tii: IDLE
[INFO]cmd: deploy
[INFO]State written to listener 0 from element /tii: INSTALLING
[INFO]The version of metadata: /gos-a/dushell/files/TII_TegraA.json is 1.0
[ERR][dutii_mdparser.c:884]Not support metadata v1 commands
[WARN]Fail to dutiiDeployMetadata: /gos-a/dushell/files/TII_TegraA.json
[INFO]State written to listener 0 from element /tii: ERROR
[WARN]Action ID 0 resulted in error state
[INFO]cmd: clear_error
The contents of the TII_TegraA.json file are as follows:
    "metaVersion" : "1.0",
    "procedure": [
            "cmd":"install_brbct_mb1",
            "a_mb1_path":"2_mb1_zerosign.bin",
            "b_mb1_path":"3_mb1_zerosign.bin",
            "a_brbct_path":"A_bct_BR_zerosign.bct",
            "b_brbct_path":"B_bct_BR_zerosign.bct"
            "cmd":"install_img",
            "partition_name":"mem-bct",
            "img_fname":"B_bct_MEM_zerosign.bct"
            "cmd":"install_group_img",
            "img_group": [
                    "partition_name":"bpmp-fw",
                    "img_fname":"B_11_bpmp_zerosign.bin"
                    "partition_name":"cpu-bootloader",
                    "img_fname":"B_9_qb_cpu_zerosign.bin"
                    "partition_name":"bpmp-fw-dtb",
                    "img_fname":"B_12_bpmp_zerosign.dtb"
            "cmd":"install_ gpt",
            "guest_id":"1",
            "gpt_path":"B_1_1_PT.bin"
            "cmd":"install_pt_brbct",
            "pt_path":"4_PT.bin",
            "cmd":"switch_bootchain",
		   "cmd":"reboot"
From the above results, tii does not support the v1 command. Can you provide a metadata example of the v2 version?
Dear @mayinghua,
Could you please check private message.
Dear @mayinghua,
Let me check internally and get back to you.
