Failed to fake EDID
Hello Everyone,
I have a system with Two A6000’s. I’m trying to set a fake EDID via one of the samples from the NVWMI developer pack. But it keeps failing to set the fake EDID. I tried different EDID’s, outputs and ports but are not managing to get it running. The EDID is found and is accepted if i manually set the EDID in Nvidia Control Panel.
I am able to unfake all EDID’s if i manually enable a EDID with the sample script.
Could someone help me out?
I’m using NVWMI 2.33 and i just noticed that the a6000 is not listed as a supported GPU. Could this be the issue?
