Failed to find/load /boot/extlinux/extlinux.conf
Hi experts,
I want to use FDT method to update dtb files. But I find that the exlinux.conf file could not be found during the Cboot phase.
[0016.174] I> Loading extlinux.conf ...
[0016.174] I> Loading extlinux.conf binary from rootfs ...
[0016.175] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0016.217] I> ext4_read_data_from_extent:298: Total file read should not be larger than file stat size
[0016.218] E> file /sdmmc_user/boot/extlinux/extlinux.conf read failed!!
[0016.219] W> Failed to load extlinux.conf binary from rootfs (err=202113305)
[0016.219] E> Failed to find/load /boot/extlinux/extlinux.conf
My machine environment :
  • NVIDIA Jetson Xavier NX (Developer Kit Version)
    • Jetpack 4.6.2 [L4T 32.7.2]
    • NV Power Mode: MODE_10W_DESKTOP - Type: 5
    • jetson_stats.service: active
bootup.log (214.9 KB)
I wonder why exlinux files are not recognized? And can this version use FDT to specify device tree files?
This is a bug in cboot. Need to apply this patch to cboot.
https://elinux.org/Jetson/L4T/r32.7.x_patches
Hi Waynewww,
Thank you for your reply. I apply the patch, and it works well.
But I get a new issue. How can I get encrypted binary files and signature files of dtb and exlinux.conf?
I can’t find instructions in this development document.
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SD/Kernel/KernelCustomization.html?highlight=sign
This is my cboot log:
[0016.073] I> Detect filesystem
[0016.100] I> Loading extlinux.conf ...
[0016.101] I> Loading extlinux.conf binary from rootfs ...
[0016.101] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0016.144] I> Loading extlinux.conf sig file from rootfs ...
[0016.144] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf.sig
[0016.175] I> overload load_size to 864 (from 894)
[0016.175] I> Validate extlinux.conf ...
[0016.176] I> T19x: Authenticate extlinux.conf (bin_type: 54), max size 0x2000
[0016.176] E> digest on binary did not match!!
[0016.177] C> OEM authentication of extlinux.conf payload failed!
[0016.177] W> Failed to validate extlinux.conf binary from rootfs (err=1077936152, fail=0)
[0016.183] W> Security fuse not burned, ignore validation failure
[0016.189] I> restore load_size to 894
[0016.193] I> L4T boot options
[0016.195] I> [1]: "primary kernel"
[0016.199] I> Enter choice:
[0019.202] I> Continuing with default option: 1
[0019.202] I> Loading kernel ...
[0019.202] I> Loading kernel binary from rootfs ...
[0019.203] I> rootfs path: /sdmmc_user/boot/Image
[0019.602] I> Loading kernel sig file from rootfs ...
[0019.603] I> rootfs path: /sdmmc_user/boot/Image.sig
[0019.621] I> overload load_size to 34484232 (from 34484240)
[0019.622] I> Validate kernel ...
[0019.622] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0019.936] I> Encryption fuse is not ON
[0019.966] I> Loading kernel-dtb ...
[0019.966] I> Loading kernel-dtb binary from rootfs ...
[0019.966] I> rootfs path: /sdmmc_user/boot/dtb/taihu.dtb
[0019.998] I> Loading kernel-dtb sig file from rootfs ...
[0019.998] I> rootfs path: /sdmmc_user/boot/dtb/taihu.dtb.sig
[0026.196] I> lookup_linear_dir:481: Invalid file block num
[0026.197] I> ext2_walk:142: 'taihu.dtb.sig' lookup failed
[0026.197] I> ext4_open_file:700: '/boot/dtb/taihu.dtb.sig' lookup failed
[0026.197] E> file /sdmmc_user/boot/dtb/taihu.dtb.sig open failed!!
[0026.198] W> Failed to load kernel-dtb sig file (err=202113041)
[0026.200] I> Validate kernel-dtb ...
[0026.203] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0026.210] E> Stage2Signature validation failed with SHA2!!
[0026.216] C> OEM authentication of kernel-dtb header failed!
[0026.221] W> Failed to validate kernel-dtb binary from rootfs (err=1077936152, fail=1)
[0026.229] W> Security fuse not burned, ignore validation failure
[0026.235] I> restore load_size to 204640
Do you mean you want to enable secure boot?
No, I don’t want to use secure boot.
So, I wander if I don’t enable secure boot, Do I still need encrypted binary files and signature files?
Can I disable the secure boot validation in Cboot to reduce boot up time?
You can. But need to modify the code by yourself.
