Failed to Flash 64 Bit OS to TX1 device
I tried to flash OS by JetPack, but failed.
Version tried: JetPack 3.2.1 (tried twice), Jetpack 2.3.1
Message from JetPack L4T on ubuntu host:
[ 2.4632 ] Flashing the device
[ 2.4657 ] tegradevflash --pt flash.bin --storageinfo storage_info.bin --create
[ 2.4670 ] Cboot version 00.01.0000
[ 3.1882 ] Writing partition GPT with gpt.bin
[ 3.1886 ] […] 100%
[ 3.1939 ] 00000007: Written less bytes than expected
[ 3.3821 ]
Error: Return value 7
Command tegradevflash --pt flash.bin --storageinfo storage_info.bin --create
Failed flashing t210ref.
0
Failed to flash device. Please check /home/tedxie/JetPack/_installer/logs/64_TX1/flash_os_64_tx1.log for more details. Then press Enter key and try again.
Message from serial terminal of TX1:
[1329.342] Writing protective mbr
[1329.346] Writing primary GPT
[1329.351] Writing secondary GPT
[1329.356] Found 0 GPT partitions in “sdmmc3_user”
[1329.361] device_write_gpt: failed to scan partitions in GPT!
[1329.367] Number of bytes written -1
[1329.370] Written less bytes than expected with error 0x7
[1329.376] Write command failed for GPT partition
Hi, added a comment here before I saw this thread:
https://devtalk.nvidia.com/default/topic/928477/jetson-tx1/flash-problem/post/5266682/#5266682
Added note: You can log a command line flash. Instead of this:
sudo ./flash.sh -S 14580MiB jetson-tx1 mmcblk0p1
…use:
sudo ./flash.sh -S 14580MiB jetson-tx1 mmcblk0p1 <b>2>&1 | tee flash_log.txt</b>
Thanks for your reply.
I changed ROOTFSSIZE in jetson-tx1.conf from “14GiB” to “6GiB”, and retry. It works.
The TX1 here is customized, which has much smaller storage.
