Host:ubuntu 16.04
jetpack version : 3.2.1
Currently Im using ethernet cable to connect host and tx2 without router which i have configured IP address. But the first attempt failed and when im trying to reflash tx2. I notice there is no network interface selection anymore, after selecting and installing packages, it asked me to put TX2 in force USB mode.
First question: is it normal that failed flashing causes TX2 wouldnt boot ubuntu system? not until i finished flashing successfully?
Second Question: Why there is no network interface selection page?
Thank you for helping.
siyangcogeo,
Did you mean you choose the second network option in jetpack? Could you paste some screenshot to make the problem more clear?
It is normal that flash failure would cause system not able to boot up.
HI, i currently switch to router option now, connect everything to router.
right now Im using VM as host, but the problem is process froze at “writing partition APP with systen.img”, im also using bridge connection. I know VM is not officially supported and having all kinds of problem. I just need to make sure VM is causing this problem or not. Thank you for helping
[ 0.0078 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0100 ] Assuming zero filled SBK key
[ 0.0532 ]
[ 0.0533 ] Generating RCM messages
[ 0.0609 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0631 ] RCM 0 is saved as rcm_0.rcm
[ 0.0851 ] RCM 1 is saved as rcm_1.rcm
[ 0.0947 ] List of rcm files are saved in rcm_list.xml
[ 0.1001 ]
[ 0.1001 ] Signing RCM messages
[ 0.1103 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1121 ] Assuming zero filled SBK key
[ 0.1516 ]
[ 0.1517 ] Copying signature to RCM mesages
[ 0.1597 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.1746 ]
[ 0.1747 ] Parsing partition layout
[ 0.1832 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.2149 ]
[ 0.2149 ] Creating list of images to be signed
[ 0.2314 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.3357 ]
[ 0.3357 ] Generating signatures
[ 0.3371 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3430 ] Assuming zero filled SBK key
[ 0.5523 ]
[ 0.5523 ] Generating br-bct
[ 0.5606 ] Updating dev and MSS params in BR BCT
[ 0.5607 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.6385 ]
[ 0.6386 ] Updating bl info
[ 0.6409 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.6672 ]
[ 0.6673 ] Updating smd info
[ 0.6687 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.6883 ]
[ 0.6884 ] Updating Odmdata
[ 0.6911 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.7132 ]
[ 0.7134 ] Get Signed section bct
[ 0.7215 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.7455 ]
[ 0.7455 ] Signing BCT
[ 0.7485 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.7535 ] Assuming zero filled SBK key
[ 0.7930 ]
[ 0.7931 ] Updating BCT with signature
[ 0.7966 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.8187 ]
[ 0.8187 ] Generating coldboot mb1-bct
[ 0.8203 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.8224 ] MB1-BCT version: 0xe
[ 0.8323 ] Copying Sdram info from 2 to 3 set
[ 0.8855 ] Copying Sdram info from 0 to 1 set
[ 0.8933 ] Packing sdram param for instance[0]
[ 0.8997 ] Packing sdram param for instance[1]
[ 0.9169 ] Packing sdram param for instance[2]
[ 0.9296 ] Packing sdram param for instance[3]
[ 0.9324 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.9506 ] Appending platform config data of size :- 2904
[ 0.9506 ]
[ 0.9506 ] Parsing config file :mobile_scr.cfg
[ 0.9506 ] Appending platform config data of size :- 12240
[ 0.9506 ]
[ 0.9506 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.9506 ] Appending platform config data of size :- 24
[ 0.9506 ]
[ 0.9506 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.9506 ] Appending platform config data of size :- 708
[ 0.9506 ]
[ 0.9506 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.9506 ] Appending platform config data of size :- 64
[ 0.9506 ]
[ 0.9506 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.9506 ] Appending platform config data of size :- 1628
[ 0.9506 ]
[ 0.9507 ] Updating mb1-bct with firmware information
[ 0.9551 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.9583 ] MB1-BCT version: 0xe
[ 0.9762 ]
[ 0.9762 ] Updating mb1-bct with storage information
[ 0.9831 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.9942 ] MB1-BCT version: 0xe
[ 1.0245 ]
[ 1.0259 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 1.0434 ]
[ 1.0449 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.0727 ]
[ 1.0773 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 1.0817 ] Assuming zero filled SBK key
[ 1.1243 ]
[ 1.1263 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.1484 ]
[ 1.1485 ] Generating recovery mb1-bct
[ 1.1499 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.1516 ] MB1-BCT version: 0xe
[ 1.1591 ] Copying Sdram info from 2 to 3 set
[ 1.2169 ] Copying Sdram info from 0 to 1 set
[ 1.2197 ] Packing sdram param for instance[0]
[ 1.2272 ] Packing sdram param for instance[1]
[ 1.2404 ] Packing sdram param for instance[2]
[ 1.2483 ] Packing sdram param for instance[3]
[ 1.2483 ]
[ 1.2483 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.2483 ] Appending platform config data of size :- 2904
[ 1.2483 ]
[ 1.2483 ] Parsing config file :minimal_scr.cfg
[ 1.2483 ] Appending platform config data of size :- 12240
[ 1.2483 ]
[ 1.2483 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.2483 ] Appending platform config data of size :- 24
[ 1.2483 ]
[ 1.2483 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.2483 ] Appending platform config data of size :- 708
[ 1.2483 ]
[ 1.2483 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.2483 ] Appending platform config data of size :- 64
[ 1.2483 ]
[ 1.2483 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.2483 ] Appending platform config data of size :- 1628
[ 1.2483 ]
[ 1.2484 ] Updating mb1-bct with firmware information
[ 1.2497 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.2604 ] MB1-BCT version: 0xe
[ 1.2787 ]
[ 1.2788 ] Updating mb1-bct with storage information
[ 1.2813 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.2920 ] MB1-BCT version: 0xe
[ 1.3245 ]
[ 1.3260 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 1.3402 ]
[ 1.3417 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.3762 ]
[ 1.3780 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 1.3793 ] Assuming zero filled SBK key
[ 1.4039 ]
[ 1.4059 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.4306 ]
[ 1.4309 ] Copying signatures
[ 1.4331 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.4986 ]
[ 1.4987 ] Boot Rom communication
[ 1.5003 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.5055 ] BootRom is not running
[ 2.5324 ]
[ 2.5338 ] tegrarcm_v2 --isapplet
[ 2.5354 ] Applet version 01.00.0000
[ 2.6963 ]
[ 2.6964 ] Retrieving board information
[ 2.6987 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 2.7056 ] Applet version 01.00.0000
[ 2.8275 ] Saved platform info in chip_info.bin
[ 2.8984 ] Chip minor revision: 2
[ 2.9562 ]
[ 2.9563 ] Sending BCTs
[ 2.9582 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 2.9641 ] Applet version 01.00.0000
[ 3.0951 ] Sending bct_bootrom
[ 3.0973 ] [................................................] 100%
[ 3.1717 ] Sending bct_mb1
[ 3.2211 ] [................................................] 100%
[ 3.7321 ]
[ 3.7321 ] Generating blob
[ 3.7337 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 3.7500 ]
[ 3.7524 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 3.7727 ]
[ 3.7747 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 3.7761 ] Assuming zero filled SBK key
[ 3.8204 ]
[ 3.8225 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 3.8454 ]
[ 3.8470 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 3.8770 ]
[ 3.8785 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 3.8929 ]
[ 3.9027 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 3.9042 ] Assuming zero filled SBK key
[ 3.9385 ]
[ 3.9404 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 3.9636 ]
[ 3.9734 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 3.9801 ]
[ 3.9820 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 4.0054 ]
[ 4.0092 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 4.0139 ] Assuming zero filled SBK key
[ 4.0413 ]
[ 4.0487 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 4.0738 ]
[ 4.0755 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 4.0907 ]
[ 4.0935 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 4.1324 ]
[ 4.1343 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 4.1357 ] Assuming zero filled SBK key
[ 4.2922 ]
[ 4.2941 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 4.3124 ]
[ 4.3143 ] tegrahost_v2 --align blob_bpmp.bin
[ 4.3328 ]
[ 4.3342 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 4.3587 ]
[ 4.3682 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 4.3696 ] Assuming zero filled SBK key
[ 4.4402 ]
[ 4.4430 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 4.4710 ]
[ 4.4792 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 4.5016 ]
[ 4.5032 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 4.5292 ]
[ 4.5334 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 4.5435 ] Assuming zero filled SBK key
[ 4.5886 ]
[ 4.5971 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 4.6161 ]
[ 4.6177 ] tegrahost_v2 --align blob_tos.img
[ 4.6327 ]
[ 4.6404 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 4.6747 ]
[ 4.6861 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 4.6878 ] Assuming zero filled SBK key
[ 4.7304 ]
[ 4.7335 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 4.7483 ]
[ 4.7588 ] tegrahost_v2 --align blob_eks.img
[ 4.7721 ]
[ 4.7764 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 4.7945 ]
[ 4.8004 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 4.8093 ] Assuming zero filled SBK key
[ 4.8432 ]
[ 4.8451 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 4.8652 ]
[ 4.8667 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 4.8887 ]
[ 4.8905 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 4.9127 ]
[ 4.9205 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 4.9225 ] Assuming zero filled SBK key
[ 4.9917 ]
[ 4.9938 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 5.0093 ]
[ 5.0228 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 5.0245 ] number of images in blob are 9
[ 5.0347 ] blobsize is 3725048
[ 5.0373 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 184576
[ 5.0505 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 78080
[ 5.0626 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 61472
[ 5.0880 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2077088
[ 5.1118 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 528800
[ 5.1247 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 5.1323 ] Added binary blob_tos_sigheader.img.encrypt of size 58880
[ 5.1324 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 5.1324 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 268352
[ 5.1324 ]
[ 5.1324 ] Sending bootloader and pre-requisite binaries
[ 5.1340 ] tegrarcm_v2 --download blob blob.bin
[ 5.1382 ] Applet version 01.00.0000
[ 5.2742 ] Sending blob
[ 5.2746 ] [.............. ] 028%
[ 5.2746 ] [............................ ] 056%
[ 5.2746 ] [.......................................... ] 084%
[ 5.2746 ] [................................................] 100%
[ 6.6624 ]
[ 6.6642 ] tegrarcm_v2 --boot recovery
[ 6.6664 ] Applet version 01.00.0000
[ 6.8613 ]
[ 6.8627 ] tegrarcm_v2 --isapplet
[ 7.5141 ]
[ 7.5217 ] tegradevflash_v2 --iscpubl
[ 7.5245 ] CPU Bootloader is not running on device.
[ 9.6116 ]
[ 11.0030 ] Retrieving storage infomation
[ 11.0050 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 11.0067 ] Applet is not running on device. Continue with Bootloader
[ 11.1584 ]
[ 11.1606 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 11.1679 ] Bootloader version 01.00.0000
[ 11.2914 ] Saved platform info in storage_info.bin
[ 11.4123 ]
[ 11.4123 ] Flashing the device
[ 11.4150 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 11.4399 ]
[ 11.4442 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 11.4458 ] Bootloader version 01.00.0000
[ 11.5718 ] Erasing sdmmc_boot: 3 ......... [Done]
[ 11.6863 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 11.6875 ] [................................................] 100%
[ 11.8834 ] Erasing sdmmc_user: 3 ......... [Done]
[ 12.5648 ] Writing partition master_boot_record with mbr_1_3.bin
[ 12.5660 ] [................................................] 100%
[ 12.6457 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 12.6956 ] [................................................] 100%
[ 12.7791 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 12.8389 ] [................................................] 100%
[ 12.9817 ] Append 256 to mb1_prod.bin.encrypt
[ 12.9823 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 12.9832 ] [................................................] 100%
[ 13.0786 ] Append 96 to spe_sigheader.bin.encrypt
[ 13.1301 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 13.1312 ] [................................................] 100%
[ 13.2295 ] Append 480 to nvtboot_sigheader.bin.encrypt
[ 13.2915 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 13.2987 ] [................................................] 100%
[ 13.3908 ] Append 480 to preboot_d15_prod_cr_sigheader.bin.encrypt
[ 13.4452 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 13.4482 ] [................................................] 100%
[ 13.5344 ] Writing partition master_boot_record with mbr_1_3.bin
[ 13.5930 ] [................................................] 100%
[ 13.6677 ] Writing partition APP with system.img
[ 13.7178 ] [ ] 000%
[ 13.7178 ] [ ] 001%
[ 13.7178 ] [. ] 002%
[ 13.7178 ] [. ] 003%
[ 13.7178 ] [.. ] 004%
[ 13.7178 ] [.. ] 005%
[ 13.7178 ] [... ] 006%
[ 13.7178 ] [... ] 007%
[ 13.7178 ] [.... ] 008%
[ 13.7178 ] [.... ] 009%
[ 13.7178 ] [..... ] 010%
[ 13.7178 ] [..... ] 011%
[ 13.7178 ] [...... ] 012%
[ 13.7178 ] [...... ] 013%
[ 1137.0732 ]
Error: Return value 3
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
If you only managed to write 13% of the APP partition I would be surprised if it turned on.
A VM won’t work because during the flashing process the TX will re-enumerate the USB several times, when it does it will reattach to the host operating system and the VM will lose control of it. You could use a VM on some early builds because things weren’t quite so sophisticated, but it plain doesn’t work now.
I’d recommend using an old laptop, or setting up dual boot on your primary computer. Honestly you might be able to flash it from a bootable Ubuntu drive too, anything where the OS has full control of the hardware.
Hi all,
I have finished flashing and install tensorflow on TX2, i want to share some of my experience that may help u.
Flashing:
1.If you want to build tensorflow from source or wheel file, choose correct version of jetpack that containing correct version of CUDA and cuDNN for different TF
https://www.tensorflow.org/install/install_sources
2.You dont have to selection all packages to flashing, but if missing network interface option page means you need more packages
3.DONT USE VM
4.USE Router
5.time duration for flashing : about 1 hour
Installing tensorflow
1.install from wheel file(easier and faster) or build from source file
2.build Tensorflow failure may caused by wrong version of bazel
check installed bazel version
$ bazel version
If you have more problem, feel free to leave comment
