We recently reflash 6.0.4 drive sdk using instructions in [DRIVE_OS_6.0.4.0_Debian_Package_Installation_Guide_NVONLINE.pdf].
After we executing the command:
tools/flashtools/bootburn/bootburn.py -b p3710-10-a01 -B qspi
we get the following errors:
[bootburnTegra-A]: [CheckFuseForAuthentication(803)] : Target Authentication State : SHA-2
[bootburnTegra-A]: [GenAdbSerialNum(576)] : ADB serial number is 8S2TQKFH8000008G20I0
[bootburnTegra-A]: [CheckForDeviceType(901)] : Detected ES production device type
*** in targetConfig, s_BrickOnTCFFlashingFail not found in board_config ***
*** in targetConfig, s_BrickOnFirmwareFlashingFail not found in board_config ***
[bootburnTegra-A]: creating and flashing coldboot images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(613)] : Creating & Flashing images
[bootburnTegra-A]: Creating rcm-flash images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(616)] : flashingCFG :: /home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/flashing_kernel/flashing_configs/t23x/quickboot_flashing.cfgself.targetConfig.p_OutDirPath :: /home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn_t23x_py/__temp_t234/Tegra-A-dba4ded162d
[bootburnTegra-A]: [GenerateImage(2411)] : Generating Flashing-RCM Images
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(620)] : Generating cold boot flash-images
[bootburnTegra-A]: [GenerateImage(2430)] : Generating Flash Images for chain A, this may take a few minutes
[bootburnTegra-A]: [GenerateImage(2430)] : Generating Flash Images for chain B, this may take a few minutes
[bootburnTegra-A]: [GenerateImage(2430)] : Generating Flash Images for chain C, this may take a few minutes
[bootburnTegra-A]: [Boot_Create_Flash_Coldboot(624)] : Booting Flashing Kernel
[bootburnTegra-A]: [BootRCM_FPGA(531)] : BootRCM_FPGA - rcm-flash
[bootburnTegra-A]: [executeShellCommand(164)] : shell command – sudo -E /home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/011 --download bct_br ./APbct_BR_zerosign.bct failed
[bootburnTegra-A]: [executeShellCommand(166)] : Output: Sending bct_br
ERROR: might be timeout in USB write.
[bootburnTegra-A]: [executeShellCommand(168)] : Return code: 3
[bootburnTegra-A]: [sendRcmCommand(767)] : Unable to execute tegrarcm command – sudo -E /home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/flash/tegrarcm_v2 --instance /dev/bus/usb/003/011 --download bct_br ./APbct_BR_zerosign.bct
command line used was:
[‘tools/flashtools/bootburn/bootburn.py’, ‘-b’, ‘p3710-10-a01’, ‘-B’, ‘qspi’]
TEGRARCM – Unable to execute command
Exception 43 raised in bootburn_active
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn.py”, line 156, in bootburn_active
bootburnOrin.Boot_Create_Flash_Coldboot()
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 625, in Boot_Create_Flash_Coldboot
self.BootRCM_FPGA(“rcm-flash”, self.targetConfig.p_OutDirPath)
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 550, in BootRCM_FPGA
self.BootMb2Applet(l_Operation, binaryLocation)
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_orin.py”, line 397, in BootMb2Applet
self.sendRcmCommand("–download bct_br " + brbct)
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/bootburn_lib.py”, line 768, in sendRcmCommand
AbnormalTermination(“TEGRARCM – Unable to execute command”, nverror.NvError_TegraRcmError)
File “/home/l4-1804/drivesdk6/drive-foundation/tools/flashtools/bootburn/…/bootburn_t23x_py/flashtools_nverror.py”, line 249, in AbnormalTermination
raise OSError(errorCode)
OSError: 43
[bootburnTegra-A]: [updateFindBoardData(353)] : Connected Board Name details ::
returning to directory /home/l4-1804/drivesdk6/drive-foundation
Cleaning up …
Cleaning temp dir
So can someone help us, thankyou!!!
