Hi
I tried the latest version SDK Manager. It has no issue on install the components after flashed from the SDK Manager (but with the storage limitation). I did not flash with the flash script yet.
I can’t use latest SDK Manager as it resulted the version conflict when I install the e-con system camera development SDK. I was instructed to use SDK Manager 4.3 by e-con system support.
I can ping Jetson Nano from Ubuntu 18.04 host at IP: 192.168.55.1. The average response time is 3ms. But the install components failed. Please refer to the log below:
SDKM_logs_JetPack_4.3_Linux_for_Jetson_Nano_[developer_kit_version]_2020-09-02_07-56-21.zip (173.9 KB)
Actually, it is just through internet or virtual usb-internet interface. Not a special trick. You can install components even from the other side of the earth once you have a valid IP.
Is it means that I can install the components from Jetson Nano? If yes, can I transfer the files in the download folder of the host machine to Jetson Nano to do the installation? If can, would you please give me the list of the files to be installed in the order order of installation sequence.
Changwen
