Failed to flash Jetson Xavier NX 16GB module - Erasing spi Failed
When we try to flash the Jetson Xavier NX 16GB module with BSP version 35.1.0 we are getting the error “Erasing spi: 0 … [Failed]” as shown below (Attached the complete log). What could be the reason?
[ 9.9149 ] 13 kernel-dtb_b 2970636829707263
[ 9.9149 ] 14 reserved_for_chain_B_user 2970726429773823
[ 9.9149 ] 15 recovery 2977382429937663
[ 9.9149 ] 16 recovery-dtb 2993766429938687
[ 9.9149 ] 17 RECROOTFS 2993868830143487
[ 9.9149 ] 18 esp 3014348830274559
[ 9.9149 ] 19 UDA 3027456030777310
[ 9.9149 ]
[ 9.9150 ] Start flashing
[ 9.9176 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 9.9188 ] Bootloader version 01.00.0000
[ 9.9449 ] Erasing spi: 0 … [Failed]
Error: Return value 8
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
Jetson-Xavier-NX16GB-flashing-failure-log.txt (137.0 KB)
Try to use rel-35.4.1. Rel-35.1 is too old and I don’t suggest ot use it.
