I’ve tried resetting the usb controller, a different cable and even a different computer. I am trying to flash it using the nvme drive, and I’m not sure what is causing this issue. I have successfully flashed 4 other jetson’s doing this method, both before and after this failed one. Any help would be greatly appreciated
Please first confirm the exact developer kit model. Is it a Jetson Orin Nano Developer Kit, or the original Jetson Nano Developer Kit? JetPack 7.2 supports the Jetson Orin family, but not the original Jetson Nano.
If this is a Jetson Orin Nano Developer Kit, the SDK Manager message is occurring before anything is written to the NVMe drive. Please put the affected unit into Force Recovery Mode manually, then run the following command on the Linux host:
lsusb
Please share the NVIDIA entry from the output. In Force Recovery Mode, an Orin Nano should appear as 0955:7523 for the 8GB module or 0955:7623 for the 4GB module. If neither entry appears, the issue is still at the Force Recovery/USB detection stage rather than the NVMe flashing stage.
Thanks for confirming. The 0955:7523 APX entry confirms that the 8GB Jetson Orin Nano module was in Force Recovery Mode when you checked it. However, the SDK Manager dialog does not show which subsequent readiness check is failing.
Please collect the detailed SDK Manager logs:
In SDK Manager, select ⋮ > Settings and set Log Level to Debug.
Reproduce the flash failure once.
Select ⋮ > Export Debug Logs and attach the resulting ZIP file to this topic.
