On Sep 2016, I flashed the tx1 board successfully by Jetpack 2.3.
But, today I downloaded the 2.3.1 and 2.3 pack, both failed to flash tx1.
When select the install action, I need to uninstall the libopencv4tegra, because the libopencv4tegra can not be installed on my host
However, if I move my mouse on the action check list, the jetpack software will continue bypass all procedure as expected and exit.
Does anyone else have the same issue?
