Hi, I tried to flash my jetpack tx1 with jetpack 4.3, but get the following errors:
- 04:27:10 INFO : Flash Jetson TX1 : exec_command: sudo ./flash.sh jetson-tx1 mmcblk0p1
- 04:27:10 INFO : Flash Jetson TX1 : ###############################################################################
- 04:27:10 INFO : Flash Jetson TX1 : # L4T BSP Information:
- 04:27:10 INFO : Flash Jetson TX1 : # R32 , REVISION: 3.1
- 04:27:10 INFO : Flash Jetson TX1 : # Target Board Information:
- 04:27:10 INFO : Flash Jetson TX1 : # Name: jetson-tx1, Board Family: t210ref, SoC: Tegra 186,
- 04:27:10 INFO : Flash Jetson TX1 : # OpMode: production, Boot Authentication: NS,
- 04:27:10 INFO : Flash Jetson TX1 : Error: The Actual SoC ID(0x18) mismatches intended jetson-tx1 SoC ID(0x21).
- 04:27:10 INFO : Flash Jetson TX1 : exit status 1
- 04:27:10 INFO : Flash Jetson TX1 : [ Component Install Finished with Error ]
- 04:27:10 INFO : Flash Jetson TX1 : [ 4.00 KB used. Disk Avail: 196.72 GB ]
- 04:27:10 INFO : Flash Jetson TX1 : [ NV_L4T_FLASH_TX1_WITH_OS_IMAGE_COMP Install took 2s ]
- 04:27:10 ERROR : Flash Jetson TX1 : Run commands failed at step Install: command sudo ./flash.sh jetson-tx1 mmcblk0p1 finished with error
- 04:27:10 ERROR : Flash Jetson TX1 : command terminated with error
- 04:27:10 ERROR : Flash Jetson TX1 : install ‘Flash Jetson TX1’ failure,
It seems the version of SOC not match.
On the step 2 to select the “Target Hardware”, there only one option for TX1: “Jetson TX1(P2180)”, what does P2180 mean? How can I confirm the version of my TX1? Do you no longer support old TX1?( I bought my TX1 in 2017). How can I resolve this problem? thank you.
