Failed to get virtual display
Dear @gautam.kumar.jain1,
After flashing the board with docker, immediately when you connect to Tegra via serial console, EULA prompt is expected to come. Did you check that already?
If headless mode is ok for you, you may check Headless Mode setup failed - #2 by SivaRamaKrishnaNV
