I am using the latest Isaac sim 4.5.0 and i trying to follow [Tutorial for Visual SLAM with Isaac Sim — isaac_ros_docs documentation] to try running slam in isaacsim.
After starting isaacsim 4.5.0,I run the following command in docker:
roslaunch isaac_ros_visual_slam isaac_ros_visual_slam_isaac_sim.launch.py
i meet errors like this:
[component_container-1] [INFO] [1741668935.652562197] [visual_slam_node]: Initializing cuVSLAM.
[component_container-1] [INFO] [1741668935.652655062] [visual_slam_node]: Use use_gpu: true
[component_container-1] [INFO] [1741668935.652661279] [visual_slam_node]: Enable IMU Fusion: false
[component_container-1] [INFO] [1741668935.652668614] [visual_slam_node]: Time taken by CUVSLAM_CreateTracker(): 0.000003
[component_container-1] [ERROR] [1741668935.652706417] [visual_slam_node]: Failed to initialize CUVSLAM tracker: 4
In docker environment,the output of “nvcc -V” is : Cuda compilation tools, release 12.6, V12.6.20
In ubuntu 22.04 , I have a system-level ROS2 Humble environment
do someone know how to solve this problem?
