• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 550.90.07
I’m using deepstream docker image nvcr.io/nvidia/deepstream:6.3-gc-triton-devel (I’m unable to use 7.0 or 7.1 because of a problem with engine creation) inside an openshift pod using a 10GB MIG, when I try to run python sample test 2 the initialization of streammux fails:
root@devel-ds-6:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test2# python ./deepstream_test_2.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create Nvv4l2 Decoder
Unable to create NvStreamMux
Unable to create pgie
Unable to create tracker
Unable to make sgie1
Unable to make sgie2
Unable to make sgie3
Unable to create nvvidconv
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
File “./deepstream_test_2.py”, line 351, in
sys.exit(main(sys.argv))
File “./deepstream_test_2.py”, line 251, in main
streammux.set_property(‘width’, 1920)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
This is my nvidia-smi output:
root@devel-ds-6:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test2# nvidia-smi
Fri Dec 13 10:30:56 2024
| NVIDIA-SMI 550.90.07 Driver Version: 550.90.07 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA A100 80GB PCIe On | 00000000:98:00.0 Off | On |
| N/A 38C P0 76W / 300W | N/A | N/A Default |
| | | Enabled |
| MIG devices: |
| GPU GI CI MIG | Memory-Usage | Vol| Shared |
| ID ID Dev | BAR1-Usage | SM Unc| CE ENC DEC OFA JPG |
| | | ECC| |
| 0 9 0 0 | 13MiB / 9728MiB | 14 0 | 1 0 0 0 0 |
| | 0MiB / 16383MiB | | |
| Processes: |
| ID ID Usage |
| No running processes found |
test3 fails also:
root@devel-ds-6:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3# python deepstream_test_3.py -i file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
{‘input’: [‘file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264’], ‘configfile’: None, ‘pgie’: None, ‘no_display’: False, ‘file_loop’: False, ‘disable_probe’: False, ‘silent’: False}
Creating Pipeline
Creating streamux
File “deepstream_test_3.py”, line 487, in
sys.exit(main(stream_paths, pgie, config, disable_probe))
File “deepstream_test_3.py”, line 226, in main
pipeline.add(streammux)
File “/usr/lib/python3/dist-packages/gi/overrides/Gst.py”, line 64, in add
if not Gst.Bin.add(self, arg):
TypeError: Argument 1 does not allow None as a value
thanks.
