Failed to install Cuda 11.7 with error processing package nvidia-dkms-515
I am trying to install cuda on a small factor pc (NUC phantom canyon, NUC11PHKi7) which has an RTX2060 card and runs Ubuntu 22.04.3 LTS (jammy) .
I am trying to install CUDA 11.7 using these instructions from the nvidia website but I am hitting an error:
Loading new nvidia-515.65.01 DKMS files...
Building for 6.2.0-26-generic
Building for architecture x86_64
Building initial module for 6.2.0-26-generic
Error! Bad return status for module build on kernel: 6.2.0-26-generic (x86_64)
Consult /var/lib/dkms/nvidia/515.65.01/build/make.log for more information.
dpkg: error processing package nvidia-dkms-515 (--configure):
 installed nvidia-dkms-515 package post-installation script subprocess returned error exit status 10
Setting up libnvidia-fbc1-515:amd64 (515.65.01-0ubuntu1) ...
Setting up libnvidia-fbc1-515:i386 (515.65.01-0ubuntu1) ...
Setting up nvidia-compute-utils-515 (515.65.01-0ubuntu1) ...
Warning: The home dir /nonexistent you specified can't be accessed: No such file or directory
Adding system user `nvidia-persistenced' (UID 129) ...
Adding new group `nvidia-persistenced' (GID 137) ...
Adding new user `nvidia-persistenced' (UID 129) with group `nvidia-persistenced' ...
Not creating home directory `/nonexistent'.
In case it helps, the make.log is below:
make.log (998.7 KB)
Can you guys help with this? it will be massively appreciated!
