Failed to install DevTool_docs on DrivePX2 platform
Hi there,
I got the problem to install DevTool_docs during the environment setup for DrivePX2 via the SDK manager. The following package was failed to downloaded. Can you help on this. Thanks!
12:37:44 INFO: DevTools Documentation - host: start to download https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/DevTool_docs.zip to /home/winner/Downloads/nvidia/sdkm_downloads/DevTool_docs.zip
Dear @user102228,
Could you share the sdkm installation logs?
Hi Siva,
Please help to check the attachment. Thanks!
SDKM_logs_DRIVE_OS_5.0.10.3_SDK_with_DriveWorks_Linux_for_DRIVE_PX_2_AutoChauffeur_2021-12-22_13-24-42.zip (179.0 KB)
Dear @user102228,
Could you check if https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/DevTool_docs.zip can be downloaded from browser? Do you see /home/winner/Downloads/nvidia/sdkm_downloads/DevTool_docs.zip file on host?
Hi Siva,
I didn’t find the DevTool_docs.zip within /home/winner/Downloads/nvidia/sdkm_downloads folder.
I had re-try to install the Developer Tools and the following log had been showed on terminal window in SDKManager. It seems that I had the issue to downloaded the DevToo_docs.zip file.
17:28:35 INFO: DevTools Documentation - host: start to download https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/DevTool_docs.zip to /home/winner/Downloads/nvidia/sdkm_downloads/DevTool_docs.zip
17:28:37 ERROR: DevTools Documentation - host: DevZone get download url failed: HTTPError: Response code 403 (Forbidden).
17:28:37 : DevTools Documentation - host: download https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/DevTool_docs.zip failed, retrying 1…
Dear @user102228,
As I asked earlier, could you check manually downloding the file via browser and keep in sdkm download folder and check using sdkmanager again. Let us know how it goes?
Hi Siva,
I cannot downloaded it since it needs the DRIVE AGX privilege . I only have the privilege to access DRIVE PX2 related information.
Dear @user102228,
Login into your devzone account check downloading https://developer.nvidia.com/drive/secure/drive_bundles/Drive_50103L_SDK_b135_OS_GA/DevTool_docs.zip
It seems you are trying to download another file as per attached picture. Please see the URL in the attached picture.
Hi Siva,
When I try to download the file by the URL but it had been redirected to the other URL. The redirected URL need another privilege to access.
The original URL:
Redirected URL:
https://developer.nvidia.com/drive/secure/drive_bundles/drive_5102l_sdk_hyperion_b65/devtool_docs.zip
Dear @user102228,
Thank you for brining it to our attention. I will check internally and update you.
Dear @user102228,
May I know the what is the current version on target?
Hi Siva,
The DRIVE OS 5.0.10.3 SDK with drivework had been used. Here is the version info on the target.
nvidia@tegra-ubuntu:~$ uname -r
4.9.80-rt61-tegra
nvidia@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 4.9.80-rt61-tegra #1 SMP PREEMPT RT Tue Sep 4 11:02:44 PDT 2018 aarch64 aarch64 aarch64 GNU/Linux
Dear @user102228,
I am wondering why you are trying to flash DRIVE OS 5.0.10.3 again as the target already has the same version.
Are you just installing it on host? If so, I could see the developer tools have installed already on host. So, I don’t see any issue in in using them on host. Do you see any other modules failing/skipped on host?
Hi Siva,
The target had been flashed successfully but my question is that I cannot get the DevTool_docs.zip to be installed on my host. Without that installation, I’m not sure how can I operate the development tool correctly. Can you help to solve the download issue? Thanks!
Dear @user102228 ,
I could reproduce the issue on my side and checking on it. I don’t think there will be issue in operating developer tools. Please give a try and let us know if you see any issue.
