when i install jetpack component, 192.168.55.1 is disconnect
0. already install os image(ubuntu 18.04) by sdk manager successfully
1.there is no ip 192.168.55.1 in xavier device
2.host can’t recongize type-c usb port (front)
3.xavier is not in recovery mode
4.command lsusb in host don’t show Type-c usb:
Hi 1025784161,
After finish image flash, are you complete first init process setup?
Please connect HDMI monitor and check it boot to Desktop GUI.
Then connect flash cable (J512) from Xavier to host machine, using “ifconfig” command to check IP address.
Or you can using eth0 IP address to instead of device IP address (192.168.55.1) to install sdk components.
thanks for your advices, I solved this question by connectting HDMI monitor
