Failed to launch and attach the Issac sim in Nsight Graphics
Hello, I want to monitor the status of my GPU while running Issac sim, but I can’t launch the issac sim in Nsight Graphics. I hope I can launch aunch and attach the Issac sim in Nsight Graphics.
OS: ubuntu 22.04 LTS
Hardware:
| NVIDIA-SMI 550.76                 Driver Version: 550.76         CUDA Version: 12.4     |
|   0  NVIDIA GeForce RTX 4060 ...    Off |   00000000:01:00.0 Off |                  N/A |
| N/A   51C    P0             17W /   80W |      10MiB /   8188MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      1279      G   /usr/lib/xorg/Xorg                              4MiB |
Software:
  • NVIDIA-Nsight-Graphics-2024.1
  • isaac_sim-2023.1.1
I select the path “~/.local/share/ov/pkg/isaac_sim-2023.1.1/isaac-sim.sh” as the application executable which I can launch issac sim successfully in terminal. But I cannot launch issac sim in Nsight Graphics.
Specificaly, when I choosed “Automatically Connect”,
I got
with log
Loading user config located at: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/user.config.json'
[Info] [carb] Logging to file: /home/zhangchen/.nvidia-omniverse/logs/Kit/Isaac-Sim/2023.1/kit_20240421_192807.log
2024-04-21 11:28:07 [3ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.core-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:28:07 [3ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:28:07 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.widget.timeline-105.0.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:28:07 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.sequencer-103.4.2-dev.3+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:28:07 [4ms] [Warning] [omni.ext.plugin] [ext: omni.paint.brush.attributes-1.3.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:28:07 [5ms] [Warning] [omni.ext.plugin] [ext: omni.usd.schema.sequence-2.3.0+105.0.lx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.150s] [ext: omni.kit.async_engine-0.0.0] startup
[0.429s] [ext: omni.assets.plugins-0.0.0] startup
[0.435s] [ext: omni.datastore-0.0.0] startup
[0.437s] [ext: omni.client-1.0.1] startup
[0.450s] [ext: omni.taskagent-0.0.0] startup
[0.454s] [ext: omni.stats-0.0.0] startup
[0.457s] [ext: omni.activity.core-1.0.1] startup
[0.465s] [ext: omni.ujitso-0.0.0] startup
[0.467s] [ext: omni.hsscclient-0.0.0] startup
[0.469s] [ext: omni.activity.profiler-1.0.2] startup
[0.474s] [ext: omni.gpu_foundation-0.0.0] startup
[0.533s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.533s] [ext: carb.windowing.plugins-1.0.0] startup
[0.560s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-04-21 11:28:08 [1,185ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-P)
2024-04-21 11:28:08 [1,186ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-P)
2024-04-21 11:28:08 [1,267ms] [Warning] [carb.graphics-vulkan.plugin] Aftermath unsupported driver version - A newer driver version is required for the current features.
2024-04-21 11:28:08 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-04-21 11:28:08 [40ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip' for upload.
'crashreport.gui' exited with code 1272024-04-21 11:28:09 [174ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip'
2024-04-21 11:28:09 [175ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:'/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip' svr:'https://services.nvidia.com/submit'
2024-04-21 11:28:09 [176ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-04-21 11:28:09 [177ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CarbSdkVersion = '158.3+release158.tc9506.b2fcff1c'
2024-04-21 11:28:09 [178ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CrashTime = 'Sun Apr 21 11:28:08 2024 GMT'
2024-04-21 11:28:09 [179ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DriverShaderCacheWrapper = 'disabled'
2024-04-21 11:28:09 [180ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DumpId = 'f9fbb942-08e9-4d93-572e8a84-3ffd6367'
2024-04-21 11:28:09 [181ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   ProductName = 'OmniverseKit'
2024-04-21 11:28:09 [181ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.py.txt''
2024-04-21 11:28:09 [182ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   RetryCount = '0'
2024-04-21 11:28:09 [183ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   StartupTime = '1713698887'
2024-04-21 11:28:09 [184ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UploadSuccessful = '0'
2024-04-21 11:28:09 [185ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UptimeSeconds = '1'
2024-04-21 11:28:09 [186ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStory = ''
2024-04-21 11:28:09 [186ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-04-21 11:28:09 [187ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   Version = '105.1.2+release.133510.b82c1e1e.tc'
2024-04-21 11:28:09 [188ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_flags = '3'
2024-04-21 11:28:09 [189ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_status = 'auto-enabled'
2024-04-21 11:28:09 [190ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appName = 'Isaac-Sim'
2024-04-21 11:28:09 [191ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appState = 'startup'
2024-04-21 11:28:09 [192ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appVersion = '2023.1.1'
2024-04-21 11:28:09 [193ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   autoloadExts = ''
2024-04-21 11:28:09 [193ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildBranch = 'release'
2024-04-21 11:28:09 [194ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildCi = 'tc'
2024-04-21 11:28:09 [195ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildHash = 'b82c1e1e'
2024-04-21 11:28:09 [196ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildId = '18571592'
2024-04-21 11:28:09 [197ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMajor = '105'
2024-04-21 11:28:09 [198ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMinor = '1'
2024-04-21 11:28:09 [199ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMr = '0'
2024-04-21 11:28:09 [200ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildNumber = '133510'
2024-04-21 11:28:09 [201ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildPatch = '2'
2024-04-21 11:28:09 [202ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildVersion = '105.1.2'
2024-04-21 11:28:09 [203ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   commandLine = '/home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/kit /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps/omni.isaac.sim.kit --ext-folder /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps'
2024-04-21 11:28:09 [204ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   email = ''
2024-04-21 11:28:09 [205ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   environmentName = 'default'
2024-04-21 11:28:09 [206ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   experience = 'Isaac Sim'
2024-04-21 11:28:09 [207ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   memoryStats = '(avail/total) RAM: 8.45263/15.2755GB, Swap: 45.7903/47.6846GB, VM: 1.71799e+10/1.71799e+10GB'
2024-04-21 11:28:09 [208ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   nvidia-smi = 'Sun Apr 21 19:28:07 2024
| N/A   52C    P0             17W /   80W |      10MiB /   8188MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A      1279      G   ............./Xorg                              4MiB |
2024-04-21 11:28:09 [209ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   portableMode = '0'
2024-04-21 11:28:09 [210ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   telemetrySessionId = '7046581435142822895'
2024-04-21 11:28:09 [211ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   terminatedByAbort = '0'
2024-04-21 11:28:09 [212ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   userId = 'default'
2024-04-21 11:28:09 [212ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   workingDirectory = '/home/<username>/softwares/omniverse'
2024-04-21 11:28:09 [213ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-04-21 11:28:09 [214ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   upload_file_minidump = '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip'
2024-04-21 11:28:11 [2,404ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip', code:200, response:
2024-04-21 11:28:11 [2,412ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]     3c113600-ffd2-11ee-b63e-02fbcab40cef
2024-04-21 11:28:11 [2,413ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save)
2024-04-21 11:28:11 [2,415ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.dmp.zip.toml'
2024-04-21 11:28:11 [2,416ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     the dump file was deleted due to a successful upload. Its originalsize was 212524 bytes and was readable.
2024-04-21 11:28:11 [2,417ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 16857 thread 16857
2024-04-21 11:28:11 [2,418ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2024-04-21 11:28:11 [2,419ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '158.3+release158.tc9506.b2fcff1c'
2024-04-21 11:28:11 [2,420ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Sun Apr 21 11:28:08 2024 GMT'
2024-04-21 11:28:11 [2,421ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2024-04-21 11:28:11 [2,421ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = 'f9fbb942-08e9-4d93-572e8a84-3ffd6367'
2024-04-21 11:28:11 [2,422ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2024-04-21 11:28:11 [2,423ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9fbb942-08e9-4d93-572e8a84-3ffd6367.py.txt''
2024-04-21 11:28:11 [2,423ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  RetryCount = '0'
2024-04-21 11:28:11 [2,424ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  StartupTime = '1713698887'
2024-04-21 11:28:11 [2,425ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UploadSuccessful = '0'
2024-04-21 11:28:11 [2,426ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UptimeSeconds = '1'
2024-04-21 11:28:11 [2,426ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UserStory = ''
2024-04-21 11:28:11 [2,427ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-04-21 11:28:11 [2,428ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  Version = '105.1.2+release.133510.b82c1e1e.tc'
2024-04-21 11:28:11 [2,428ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_flags = '3'
2024-04-21 11:28:11 [2,429ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_status = 'auto-enabled'
2024-04-21 11:28:11 [2,430ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appName = 'Isaac-Sim'
2024-04-21 11:28:11 [2,431ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appState = 'startup'
2024-04-21 11:28:11 [2,432ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appVersion = '2023.1.1'
2024-04-21 11:28:11 [2,432ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  autoloadExts = ''
2024-04-21 11:28:11 [2,433ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildBranch = 'release'
2024-04-21 11:28:11 [2,434ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildCi = 'tc'
2024-04-21 11:28:11 [2,435ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildHash = 'b82c1e1e'
2024-04-21 11:28:11 [2,435ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildId = '18571592'
2024-04-21 11:28:11 [2,436ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMajor = '105'
2024-04-21 11:28:11 [2,437ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMinor = '1'
2024-04-21 11:28:11 [2,438ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMr = '0'
2024-04-21 11:28:11 [2,438ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildNumber = '133510'
2024-04-21 11:28:11 [2,439ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildPatch = '2'
2024-04-21 11:28:11 [2,440ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildVersion = '105.1.2'
2024-04-21 11:28:11 [2,441ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  commandLine = '/home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/kit /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps/omni.isaac.sim.kit --ext-folder /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps'
2024-04-21 11:28:11 [2,442ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  email = ''
2024-04-21 11:28:11 [2,442ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  environmentName = 'default'
2024-04-21 11:28:11 [2,443ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  experience = 'Isaac Sim'
2024-04-21 11:28:11 [2,444ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  memoryStats = '(avail/total) RAM: 8.45263/15.2755GB, Swap: 45.7903/47.6846GB, VM: 1.71799e+10/1.71799e+10GB'
2024-04-21 11:28:11 [2,445ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  nvidia-smi = 'Sun Apr 21 19:28:07 2024
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
2024-04-21 11:28:11 [2,446ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  portableMode = '0'
2024-04-21 11:28:11 [2,446ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  telemetrySessionId = '7046581435142822895'
2024-04-21 11:28:11 [2,447ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  terminatedByAbort = '0'
2024-04-21 11:28:11 [2,448ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2024-04-21 11:28:11 [2,449ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/softwares/omniverse'
2024-04-21 11:28:11 [2,450ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 16857 backtrace follows:
2024-04-21 11:28:11 [2,554ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2024-04-21 11:28:11 [2,555ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libnvidia-glcore.so.550.76!+0x2a2b7b
2024-04-21 11:28:11 [2,580ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xc1d8 (??:?)
2024-04-21 11:28:11 [2,610ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xc654 (??:?)
2024-04-21 11:28:11 [2,638ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xd408 (??:?)
2024-04-21 11:28:11 [2,675ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0x1c61 (??:?)
2024-04-21 11:28:11 [2,676ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libvulkan.so.1!+0x1bfff
2024-04-21 11:28:11 [2,678ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libcarb.graphics-vulkan.plugin.so!+0x961b0
2024-04-21 11:28:11 [2,679ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libcarb.graphics-vulkan.plugin.so!+0x42f61
2024-04-21 11:28:11 [2,681ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libcarb.graphics-vulkan.plugin.so!+0x47d89
2024-04-21 11:28:11 [2,682ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libcarb.graphics-vulkan.plugin.so!+0x48063
2024-04-21 11:28:11 [2,684ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libcarb.graphics-vulkan.plugin.so!+0x4f9d4
2024-04-21 11:28:11 [2,685ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libgpu.foundation.plugin.so!+0xe2530
2024-04-21 11:28:11 [2,687ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libgpu.foundation.plugin.so!+0xe7742
2024-04-21 11:28:11 [2,688ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libgpu.foundation.plugin.so!+0xe1a82
2024-04-21 11:28:11 [2,690ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.gpu_foundation_factory.plugin.so!+0x108ff
2024-04-21 11:28:11 [2,691ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.kit.renderer.init.plugin.so!+0x12ed1
2024-04-21 11:28:11 [2,694ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.ext.plugin.so!+0x43962
2024-04-21 11:28:11 [2,697ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.ext.plugin.so!+0x3de29
2024-04-21 11:28:11 [2,700ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.ext.plugin.so!+0x213cd
2024-04-21 11:28:11 [2,702ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libomni.ext.plugin.so!+0x569a3
2024-04-21 11:28:11 [2,704ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libomni.ext.plugin.so!+0x65616
2024-04-21 11:28:11 [2,707ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libomni.ext.plugin.so!+0x66613
2024-04-21 11:28:11 [2,710ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libomni.kit.app.plugin.so!+0x2fb93
2024-04-21 11:28:11 [2,713ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libomni.kit.app.plugin.so!+0x304cc
2024-04-21 11:28:11 [2,716ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libomni.kit.app.plugin.so!+0x20b06
2024-04-21 11:28:11 [2,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: kit!_init+0x6eb (??:0)
2024-04-21 11:28:11 [2,833ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2024-04-21 11:28:11 [2,906ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2024-04-21 11:28:11 [2,929ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: kit!_start+0x29 (??:?)
When I did not choose “Automatically Connect”,
I got
but there was no process could be attached,while I can found the ceated process.
the output log is
[Info] [carb] Logging to file: /home/zhangchen/.nvidia-omniverse/logs/Kit/Isaac-Sim/2023.1/kit_20240421_193054.log
2024-04-21 11:30:54 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.core-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:30:54 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:30:54 [5ms] [Warning] [omni.ext.plugin] [ext: omni.kit.widget.timeline-105.0.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:30:54 [5ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.sequencer-103.4.2-dev.3+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:30:54 [6ms] [Warning] [omni.ext.plugin] [ext: omni.paint.brush.attributes-1.3.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-21 11:30:54 [8ms] [Warning] [omni.ext.plugin] [ext: omni.usd.schema.sequence-2.3.0+105.0.lx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.148s] [ext: omni.kit.async_engine-0.0.0] startup
[0.428s] [ext: omni.assets.plugins-0.0.0] startup
[0.438s] [ext: omni.client-1.0.1] startup
[0.451s] [ext: omni.taskagent-0.0.0] startup
[0.458s] [ext: omni.activity.core-1.0.1] startup
[0.466s] [ext: omni.ujitso-0.0.0] startup
[0.469s] [ext: omni.hsscclient-0.0.0] startup
[0.471s] [ext: omni.activity.profiler-1.0.2] startup
[0.475s] [ext: omni.gpu_foundation-0.0.0] startup
[0.534s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.535s] [ext: carb.windowing.plugins-1.0.0] startup
2024-04-21 11:30:55 [1,198ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-P)
2024-04-21 11:30:55 [1,199ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-P)
2024-04-21 11:30:55 [1,283ms] [Warning] [carb.graphics-vulkan.plugin] Aftermath unsupported driver version - A newer driver version is required for the current features.
2024-04-21 11:30:55 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-04-21 11:30:55 [57ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip' for upload.
'crashreport.gui' exited with code 1272024-04-21 11:30:55 [203ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip'
2024-04-21 11:30:55 [204ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:'/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip' svr:'https://services.nvidia.com/submit'
2024-04-21 11:30:55 [205ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-04-21 11:30:55 [205ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CarbSdkVersion = '158.3+release158.tc9506.b2fcff1c'
2024-04-21 11:30:55 [206ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CrashTime = 'Sun Apr 21 11:30:55 2024 GMT'
2024-04-21 11:30:55 [207ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DriverShaderCacheWrapper = 'disabled'
2024-04-21 11:30:55 [208ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DumpId = '0692d3c2-4a0a-44eb-78234093-7d092f2b'
2024-04-21 11:30:55 [208ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   ProductName = 'OmniverseKit'
2024-04-21 11:30:55 [209ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.py.txt''
2024-04-21 11:30:55 [210ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   RetryCount = '0'
2024-04-21 11:30:55 [211ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   StartupTime = '1713699054'
2024-04-21 11:30:55 [212ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UploadSuccessful = '0'
2024-04-21 11:30:55 [212ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UptimeSeconds = '1'
2024-04-21 11:30:55 [213ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStory = ''
2024-04-21 11:30:55 [214ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-04-21 11:30:55 [215ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   Version = '105.1.2+release.133510.b82c1e1e.tc'
2024-04-21 11:30:55 [216ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_flags = '3'
2024-04-21 11:30:55 [216ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_status = 'auto-enabled'
2024-04-21 11:30:55 [217ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appName = 'Isaac-Sim'
2024-04-21 11:30:55 [218ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appState = 'startup'
2024-04-21 11:30:55 [219ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appVersion = '2023.1.1'
2024-04-21 11:30:55 [220ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   autoloadExts = ''
2024-04-21 11:30:55 [221ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildBranch = 'release'
2024-04-21 11:30:55 [221ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildCi = 'tc'
2024-04-21 11:30:55 [222ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildHash = 'b82c1e1e'
2024-04-21 11:30:55 [223ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildId = '18571592'
2024-04-21 11:30:55 [224ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMajor = '105'
2024-04-21 11:30:55 [225ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMinor = '1'
2024-04-21 11:30:55 [226ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMr = '0'
2024-04-21 11:30:55 [227ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildNumber = '133510'
2024-04-21 11:30:55 [227ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildPatch = '2'
2024-04-21 11:30:55 [228ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildVersion = '105.1.2'
2024-04-21 11:30:55 [229ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   commandLine = '/home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/kit /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps/omni.isaac.sim.kit --ext-folder /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps'
2024-04-21 11:30:55 [230ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   email = ''
2024-04-21 11:30:55 [231ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   environmentName = 'default'
2024-04-21 11:30:55 [232ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   experience = 'Isaac Sim'
2024-04-21 11:30:55 [233ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   memoryStats = '(avail/total) RAM: 8.38833/15.2755GB, Swap: 45.7903/47.6846GB, VM: 1.71799e+10/1.71799e+10GB'
2024-04-21 11:30:55 [234ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   nvidia-smi = 'Sun Apr 21 19:30:54 2024
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
2024-04-21 11:30:55 [235ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   portableMode = '0'
2024-04-21 11:30:55 [236ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   telemetrySessionId = '14567021256840494287'
2024-04-21 11:30:55 [237ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   terminatedByAbort = '0'
2024-04-21 11:30:55 [237ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   userId = 'default'
2024-04-21 11:30:55 [241ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   workingDirectory = '/home/<username>/softwares/omniverse'
2024-04-21 11:30:55 [242ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-04-21 11:30:55 [242ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   upload_file_minidump = '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip'
2024-04-21 11:30:57 [2,034ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip', code:200, response:
2024-04-21 11:30:57 [2,043ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]     9f4490f0-ffd2-11ee-b63e-02fbcab40cef
2024-04-21 11:30:57 [2,044ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save)
2024-04-21 11:30:57 [2,045ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.dmp.zip.toml'
2024-04-21 11:30:57 [2,046ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     the dump file was deleted due to a successful upload. Its originalsize was 211856 bytes and was readable.
2024-04-21 11:30:57 [2,047ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 17181 thread 17181
2024-04-21 11:30:57 [2,048ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2024-04-21 11:30:57 [2,049ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '158.3+release158.tc9506.b2fcff1c'
2024-04-21 11:30:57 [2,050ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Sun Apr 21 11:30:55 2024 GMT'
2024-04-21 11:30:57 [2,051ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2024-04-21 11:30:57 [2,051ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = '0692d3c2-4a0a-44eb-78234093-7d092f2b'
2024-04-21 11:30:57 [2,052ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2024-04-21 11:30:57 [2,053ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zhangchen/.local/share/ov/data/Kit/Isaac-Sim/2023.1/0692d3c2-4a0a-44eb-78234093-7d092f2b.py.txt''
2024-04-21 11:30:57 [2,054ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  RetryCount = '0'
2024-04-21 11:30:57 [2,055ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  StartupTime = '1713699054'
2024-04-21 11:30:57 [2,055ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UploadSuccessful = '0'
2024-04-21 11:30:57 [2,056ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UptimeSeconds = '1'
2024-04-21 11:30:57 [2,058ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UserStory = ''
2024-04-21 11:30:57 [2,058ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-04-21 11:30:57 [2,059ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  Version = '105.1.2+release.133510.b82c1e1e.tc'
2024-04-21 11:30:57 [2,060ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_flags = '3'
2024-04-21 11:30:57 [2,061ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_status = 'auto-enabled'
2024-04-21 11:30:57 [2,062ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appName = 'Isaac-Sim'
2024-04-21 11:30:57 [2,062ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appState = 'startup'
2024-04-21 11:30:57 [2,063ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  appVersion = '2023.1.1'
2024-04-21 11:30:57 [2,064ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  autoloadExts = ''
2024-04-21 11:30:57 [2,065ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildBranch = 'release'
2024-04-21 11:30:57 [2,066ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildCi = 'tc'
2024-04-21 11:30:57 [2,067ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildHash = 'b82c1e1e'
2024-04-21 11:30:57 [2,068ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildId = '18571592'
2024-04-21 11:30:57 [2,069ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMajor = '105'
2024-04-21 11:30:57 [2,069ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMinor = '1'
2024-04-21 11:30:57 [2,070ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildMr = '0'
2024-04-21 11:30:57 [2,071ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildNumber = '133510'
2024-04-21 11:30:57 [2,072ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildPatch = '2'
2024-04-21 11:30:57 [2,073ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  buildVersion = '105.1.2'
2024-04-21 11:30:57 [2,074ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  commandLine = '/home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/kit /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps/omni.isaac.sim.kit --ext-folder /home/<username>/.local/share/ov/pkg/isaac_sim-2023.1.1/apps'
2024-04-21 11:30:57 [2,074ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  email = ''
2024-04-21 11:30:57 [2,075ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  environmentName = 'default'
2024-04-21 11:30:57 [2,076ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  experience = 'Isaac Sim'
2024-04-21 11:30:57 [2,077ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  memoryStats = '(avail/total) RAM: 8.38833/15.2755GB, Swap: 45.7903/47.6846GB, VM: 1.71799e+10/1.71799e+10GB'
2024-04-21 11:30:57 [2,078ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  nvidia-smi = 'Sun Apr 21 19:30:54 2024
|                                         |                        |                  N/A |
| Processes:        |
|        ID   ID                                                               Usage      |
2024-04-21 11:30:57 [2,079ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  portableMode = '0'
2024-04-21 11:30:57 [2,079ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  telemetrySessionId = '14567021256840494287'
2024-04-21 11:30:57 [2,080ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  terminatedByAbort = '0'
2024-04-21 11:30:57 [2,081ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2024-04-21 11:30:57 [2,082ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/softwares/omniverse'
2024-04-21 11:30:57 [2,083ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 17181 backtrace follows:
2024-04-21 11:30:57 [2,182ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2024-04-21 11:30:57 [2,184ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libnvidia-glcore.so.550.76!+0x2a2b7b
2024-04-21 11:30:57 [2,209ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xc1d8 (??:?)
2024-04-21 11:30:57 [2,244ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xc654 (??:?)
2024-04-21 11:30:57 [2,290ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0xd408 (??:?)
2024-04-21 11:30:57 [2,340ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libWarpVizTarget.so!DISPATCH_vkGetDeviceProcAddr+0x1c61 (??:?)
2024-04-21 11:30:57 [2,341ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libvulkan.so.1!+0x1bfff
2024-04-21 11:30:57 [2,342ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libcarb.graphics-vulkan.plugin.so!+0x961b0
2024-04-21 11:30:57 [2,344ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libcarb.graphics-vulkan.plugin.so!+0x42f61
2024-04-21 11:30:57 [2,345ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libcarb.graphics-vulkan.plugin.so!+0x47d89
2024-04-21 11:30:57 [2,346ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libcarb.graphics-vulkan.plugin.so!+0x48063
2024-04-21 11:30:57 [2,348ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libcarb.graphics-vulkan.plugin.so!+0x4f9d4
2024-04-21 11:30:58 [2,349ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libgpu.foundation.plugin.so!+0xe2530
2024-04-21 11:30:58 [2,350ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libgpu.foundation.plugin.so!+0xe7742
2024-04-21 11:30:58 [2,352ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libgpu.foundation.plugin.so!+0xe1a82
2024-04-21 11:30:58 [2,353ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.gpu_foundation_factory.plugin.so!+0x108ff
2024-04-21 11:30:58 [2,354ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.kit.renderer.init.plugin.so!+0x12ed1
2024-04-21 11:30:58 [2,357ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.ext.plugin.so!+0x43962
2024-04-21 11:30:58 [2,359ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.ext.plugin.so!+0x3de29
2024-04-21 11:30:58 [2,362ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.ext.plugin.so!+0x213cd
2024-04-21 11:30:58 [2,364ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libomni.ext.plugin.so!+0x569a3
2024-04-21 11:30:58 [2,365ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libomni.ext.plugin.so!+0x65616
2024-04-21 11:30:58 [2,367ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libomni.ext.plugin.so!+0x66613
2024-04-21 11:30:58 [2,369ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libomni.kit.app.plugin.so!+0x2fb93
2024-04-21 11:30:58 [2,371ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libomni.kit.app.plugin.so!+0x304cc
2024-04-21 11:30:58 [2,373ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libomni.kit.app.plugin.so!+0x20b06
2024-04-21 11:30:58 [2,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: kit!_init+0x6eb (??:0)
2024-04-21 11:30:58 [2,500ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2024-04-21 11:30:58 [2,572ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2024-04-21 11:30:58 [2,596ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: kit!_start+0x29 (??:?)
Hi zhang.chen,
I am not an expert of Issac sim, but can you take some try to make sure there’s no existing launcher process of Issac or any related app in backend while you launch it from Ngfx? Also choose ‘No’ for automatically connect and select the target grfx process.
An
