I am using Ubuntu 22.04 with GeForce 4080. Running nvidia-smi
, shows me this.
| NVIDIA-SMI 535.171.04 Driver Version: 535.171.04 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4080 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 44C P4 N/A / 50W | 10MiB / 12282MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2332 G /usr/lib/xorg/Xorg 4MiB |
I have been following Isaac Sim and Isaac Lab installation guide here.
I could do the Installation using Isaac Sim Binaries part to install Isaac Sim 4.0.0 (from Omniverse) and Isaac Lab without any problem.
Now, I tried to verify my installation as explained in this page. I could verify my Isaac Sim installation perfectly: either by using ${ISAACSIM_PATH}/isaac-sim.sh
or ${ISAACSIM_PYTHON_EXE} -c "print('Isaac Sim configuration is now complete.')"
and ${ISAACSIM_PATH}/standalone_examples/api/omni.isaac.core/add_cubes.py
. Isaac Sim could launch perfectly.
However, I could not launch Isaac Lab. When I run any of the two commands listed below (I run it at the top of the cloned repository) exactly as the guide told me.
# Option 1: Using the isaaclab.sh executable
# note: this works for both the bundled python and the virtual environment
./isaaclab.sh -p source/standalone/tutorials/00_sim/create_empty.py
# Option 2: Using python in your virtual environment
python source/standalone/tutorials/00_sim/create_empty.py
This is how the error looks like. Does it seem to be something with LibGL?
(isaaclab) rawin@predator-ph16-71:~/Documents/IsaacLab$ python source/standalone/tutorials/00_sim/create_empty.py
[WARN][AppLauncher]: There are no arguments attached to the ArgumentParser object. If you have your own arguments, please load your own arguments before calling the `AppLauncher.add_app_launcher_args` method. This allows the method to check the validity of the arguments and perform checks for argument names.
[INFO][AppLauncher]: Loading experience file: /home/rawin/Documents/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/../../../../../../apps/isaaclab.python.kit
Starting kit application with the following args: ['/home/rawin/Documents/IsaacLab/_isaac_sim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/rawin/Documents/IsaacLab/source/extensions/omni.isaac.lab/omni/isaac/lab/app/../../../../../../apps/isaaclab.python.kit', '--/app/tokens/exe-path=/home/rawin/Documents/IsaacLab/_isaac_sim/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1280', '--/app/renderer/resolution/height=720', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/rawin/Documents/IsaacLab/_isaac_sim/exts', '--ext-folder', '/home/rawin/Documents/IsaacLab/_isaac_sim/apps', '--/renderer/activeGpu=0', '--/physics/cudaDevice=0', '--portable', '--/app/window/hideUi=False']
Passing the following args to the base kit application: []
[Info] [carb] Logging to file: /home/rawin/.local/share/ov/pkg/isaac-sim-4.0.0/kit/logs/Kit/Isaac-Sim/4.0/kit_20240627_021503.log
2024-06-26 17:15:03 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.032s] [ext: omni.kit.async_engine-0.0.0] startup
[0.217s] [ext: omni.stats-0.0.0] startup
[0.218s] [ext: omni.client-1.1.0] startup
[0.235s] [ext: omni.datastore-0.0.0] startup
[0.236s] [ext: omni.blobkey-1.1.0] startup
[0.236s] [ext: omni.ujitso.default-1.0.0] startup
[0.236s] [ext: omni.hsscclient-0.0.0] startup
[0.237s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.237s] [ext: omni.assets.plugins-0.0.0] startup
[0.238s] [ext: omni.gpu_foundation-0.0.0] startup
[0.244s] [ext: carb.windowing.plugins-1.0.0] startup
[0.251s] [ext: omni.kit.renderer.init-0.0.0] startup
libGL error: MESA-LOADER: failed to open iris: /usr/lib/dri/iris_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: iris
libGL error: MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: No such file or directory (search paths /usr/lib/x86_64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri, suffix _dri)
libGL error: failed to load driver: swrast
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 240
Current serial number in output stream: 240
I need to find a way to launch it successfully. Could anyone help me solve how I could launch Isaac Lab?
Thank you very much in advance
