Hello, I’m using ubuntu 22.04.05 on a x86_64 platform with an RTX A4500.
When I setup Isaac ROS RealSense, in the step of Launch the Docker container, run the command:
cd ${ISAAC_ROS_WS}/src/isaac_ros_common &&
./scripts/run_dev.sh -d ${ISAAC_ROS_WS}
there is a error:
Thank you for your reply!
full rebuilding process and full log please see the following txt file and zip compressed package. full_rebuilding_process.txt (11.1 KB) log.zip (6.4 MB)
Yes, there is someting wrong with rosdep, but I am not sure what went wrong, all steps followed the official installation instructions to setup, do you think it’s the Isaac Apt Repository that’s the issue?
Hope Nvidia can provide a solution.
