• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
I can not load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so’ on Kubernete cluster
• TensorRT Version
I use the hardwares and softwares:
• Hardware Platform GPU GTX 2080Ti
• DeepStream Version 5.0
• NVIDIA GPU Driver Version: 455.45.01 CUDA Version: 11.1
When I deploy the deepstream app to kubernete I have met this problem. The streamux can not read the rtsp or file input cause of the issue above. But when I run with local docker, it worked
