Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so'
0:00:00.171282429   117 0x55c38e27c840 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 07:37:46.330: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
0:00:00.204476113   117 0x55c38e27c840 WARN                  ladspa gstladspa.c:507:plugin_init:<plugin59> no LADSPA plugins found, check LADSPA_PATH
0:00:00.213232190   117 0x55c38e27c840 WARN      GST_PLUGIN_LOADING gstplugin.c:792:_priv_gst_plugin_load_file_for_registry: module_open failed: libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:117): GStreamer-WARNING **: 07:37:46.372: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
0:00:00.295374669   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x120000: 'AVR (Audio Visual Research)' is not mapped
0:00:00.295399617   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x180000: 'CAF (Apple Core Audio File)' is not mapped
0:00:00.295410597   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x100000: 'HTK (HMM Tool Kit)' is not mapped
0:00:00.295526829   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xc0000: 'MAT4 (GNU Octave 2.0 / Matlab 4.2)' is not mapped
0:00:00.295534824   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xd0000: 'MAT5 (GNU Octave 2.1 / Matlab 5.0)' is not mapped
0:00:00.295541116   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x210000: 'MPC (Akai MPC 2k)' is not mapped
0:00:00.295548079   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0xe0000: 'PVF (Portable Voice Format)' is not mapped
0:00:00.295555543   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x160000: 'SD2 (Sound Designer II)' is not mapped
0:00:00.295564049   117 0x55c38e27c840 WARN                 default gstsf.c:97:gst_sf_create_audio_template_caps: format 0x190000: 'WVE (Psion Series 3)' is not mapped
0:00:00.589917846   116 0x55ab1b65b260 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Could not init EGL display connection
0:00:00.589953213   116 0x55ab1b65b260 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> EGL call returned error 3000
0:00:00.589960347   116 0x55ab1b65b260 ERROR            egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Couldn't setup window/surface from handle
0:00:00.589965537   116 0x55ab1b65b260 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init:<sink_sub_bin_sink1> Couldn't init EGL display
0:00:00.589969955   116 0x55ab1b65b260 ERROR          nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init:<sink_sub_bin_sink1> Failed to perform EGL init
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
App run failed
