Hello
I’m trying to install the link-driver for the Stereolabs zedx mini on my Jetson agx orin by following these guidlines:
https://nvidia-isaac-ros.github.io/getting_started/hardware_setup/sensors/zed_setup.html#camera-compatibility
I’m working with the Jetpack 6.0 and the ZED link duo.
After downloading this file:
stereolabs-zedlink-duo_1.1.1-LI-MAX96712-L4T36.3.0_arm64.deb
I’m running this command:
sudo dpkg -i stereolabs-zedlink-duo_1.1.1-LI-MAX96712-L4T36.3.0_arm64.deb
But I get this output:
Selecting previously unselected package stereolabs-zedlink-duo.
(Reading database … 224012 files and directories currently installed.)
Preparing to unpack stereolabs-zedlink-duo_1.1.1-LI-MAX96712-L4T36.3.0_arm64.deb …
Unpacking stereolabs-zedlink-duo (1.1.1-LI-MAX96712–L4T36.3.0) …
Setting up stereolabs-zedlink-duo (1.1.1-LI-MAX96712–L4T36.3.0) …
Detected DTB to update : tegra234-p3737
Detected capture card : zedlink-duo
Set FDT to : /boot/dtb/kernel_tegra234-p3737-0000+p3701-0000-nv.dtb
Failed to look up unit file state: Is a directory
Has someone a idea what I’m doing wrong?
Thanks for your help!
