Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hi team, in a single process, I tried calling NvSciIpcInit()
which return NvSciError_NotPermitted
. The code was running fine on 6.0.8.1 but failed after upgrading to 6.0.10.0. Is there some configuration that I am missing after upgrading?
I also tried the rawstream sample app from the DriveOS Docker containers (root@6.0.10.0-0009-build-linux-sdk:/drive/drive-linux/samples/nvsci/rawstream
) and it also failed to Init IPC.
./rawstream -p
0x405280 application starting
Producer unable to init ipc library (21)
Sample completed
I’m also getting this nvsciipc: nvsciipc_ioctl_get_dbsize[3299] need to set endpoint database first
in the dmesg log!
