Hello, I’m new with Isaac SDK 2020.1.
I was trying to train a custom object detection model with DetectNetv2 following the documentation. I can succesfully follow all the steps and generate the .etlt model. When I try to run inference on Isaac Sim Unity3D i get the following error passing the exported .etlt model
`2020-07-13 11:15:30.675 ERROR packages/ml/TensorRTInference.cpp@168: TRT ERROR: UffParser: Could not open /tmp/tmpfileCESgTX
2020-07-13 11:15:30.675 ERROR engine/alice/components/Codelet.cpp@229: Component ‘detect_net_inference.tensor_r_t_inference/isaac.ml.TensorRTInference’ of type ‘isaac::ml::TensorRTInference’ reported FAILURE:
Failed to parse ETLT file at /home/manuel/Desktop/tirocinio/models/resnet18_detector_cone.etlt
2020-07-13 11:15:30.675 ERROR engine/alice/backend/event_manager.cpp@42: Stopping node ‘detect_net_inference.tensor_r_t_inference’ because it reached status ‘FAILURE’
Could not read from plan (path is set to '/home/manuel/Desktop/tirocinio/models/resnet18_detector_cone.plan').failed to build the plan from frozen model /home/manuel/Desktop/tirocinio/models/resnet18_detector_cone.etlt
2020-07-13 11:15:30.675 ERROR engine/alice/backend/event_manager.cpp@42: Stopping node ‘detect_net_inference.tensor_r_t_inference’ because it reached status ‘FAILURE’`
Any suggestions? Thanks in advance
