Failed to program bfb image with BF2
Hi Team,
I am not able to program bfb image into BF2. Please guide.
[root@UVI85-32-1 home]# lspci -s $(sudo lspci -d 15b3: | head -1 | awk ‘{print $1}’) -vvv | grep “Product Name” Product Name: BlueField-2 DPU 25GbE Dual-Port SFP56, Crypto Enabled, 16GB on-board DDR, 1GbE OOB management, Tall Bracket
[root@UVI85-32-1 rsp_ws]# /usr/sbin/bfb-install --bfb DOCA_2.2.0_BSP_4.2.0_Ubuntu_22.04-2.23-07.prod.bfb --config bfb.cfg --rshim rshim0
Pushing bfb + cfg
cat: write error: Connection timed out <=> ]
9.69MiB 0:02:06 [78.5KiB/s] [ <=> ]
Failed to push BFB
DPU console logs:
[PMI] Boot image update started.
Note: Installed image will be filtered from 5031688 bytes to 3155832 bytes
Size check good, 3155832 <= 4194304
Check boot image, Status: Success
…Filtering unneeded executables…
…Preparing boot image…
…Generating boot image…
…Writing the boot image, Size: 3155968 bytes…
…Verify boot image…
Write boot image to partition 1, Status: Success
…Verify boot image…
Write boot image to partition 2, Status: Success
[PMI] Boot Image update completed, Status: Success
[PMI] Total number of updates: 1
[PMI] Errors during updates : 0
[root@UVI85-32-1 rsp_ws]# cat /dev/rshim0/misc
DISPLAY_LEVEL 0 (0:basic, 1:advanced, 2:log)
BOOT_MODE 1 (0:rshim, 1:emmc, 2:emmc-boot-swap)
BOOT_TIMEOUT 100 (seconds)
DROP_MODE 0 (0:normal, 1:drop)
SW_RESET 0 (1: reset)
DEV_NAME pcie-0000:af:00.2
DEV_INFO BlueField-2(Rev 1)
OPN_STR MBF2H332A-AEEO
