Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
Got this error today when I plugged my laptop into my docking station. The monitors just showed black screens. When I unplugged, I could still move my mouse on my laptop screen, but I wasn’t able to click any items.
Upon taking a look at the logs, I noticed this error:
Jul 03 15:54:36 razerblade15 kernel: [drm:__nv_drm_semsurf_wait_fence_work_cb [nvidia_drm]] ERROR [nvidia-drm] [GPU ID 0x00000100] Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
PC Info and Relevant Logs:
lex@razerblade15:~$ sudo inxi -GMSxxx
System:
Host: razerblade15 Kernel: 7.0.14-201.fc44.x86_64 arch: x86_64 bits: 64
compiler: gcc v: 16.1.1 clocksource: tsc
Console: pty pts/4 wm: gnome-shell DM: GDM v: 50.1 Distro: Fedora Linux
44 (Workstation Edition)
Machine:
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
serial: BY2222M73501760 Chassis: type: 10 serial: N/A
Mobo: Razer model: CH580 v: 4 serial: N/A part-nu: RZ09-0421EED3
uuid: 66376534-3534-6236-3161-656334366230 Firmware: UEFI vendor: Razer
v: 2.06 date: 11/01/2023
Graphics:
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Razer USA
driver: i915 v: kernel arch: Xe ports: active: eDP-1 empty: none
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Razer USA driver: nvidia v: 610.43.02 arch: Ampere pcie:
speed: 2.5 GT/s lanes: 8 ports: active: DP-4,DP-5 empty: DP-1, DP-2,
DP-3, HDMI-A-1, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:2560 class-ID: 0300
Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-2:3 chip-ID: 13d3:5279
class-ID: 0e02 serial: 01.00.00
Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-6.3.1:9
chip-ID: 046d:08e5 class-ID: 0102 serial: 98C1516F
Display: unspecified server: X.Org v: 24.1.12 with: Xwayland v: 24.1.12
compositor: gnome-shell driver: dri: iris
gpu: i915,nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 11520x2160 s-dpi: 96 s-size: 3048x571mm (120.00x22.48")
s-diag: 3101mm (122.09")
Monitor-1: DP-4 pos: center model: MSI G273 serial: CA7A492200589 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 165
size: 590x330mm (23.23x12.99") diag: 676mm (26.6") modes: max: 1920x1080
min: 640x480
Monitor-2: DP-5 pos: right model: MSI G273 serial: CA7A492102002 res:
min: 640x480
Monitor-3: eDP-1 pos: primary,left model: Sharp LQ156T1JW03 res:
mode: 3840x2160 hz: 240 scale: 100% (1) dpi: 287
size: 340x190mm (13.39x7.48") diag: 395mm (15.5") modes: 2560x1440
API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.3 glx-v: 1.4 es-v: 3.2
direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL GT2)
device-ID: 8086:46a6
API: EGL Message: EGL data requires eglinfo. Check --recommends.
Info: Tools: api: glxinfo gpu: nvidia-settings,nvidia-smi x11: xdriinfo,
xdpyinfo, xprop, xrandr
displayproblem.txt (114.8 KB)
nvidia-bug-report.log.gz (454.4 KB)
