Failed to run DPA NVQual test: Failed to start DPA context: DOCA_ERROR_DRIVER
I’m in the process of setting up a system with two 3140H cards and trying to go thru the “NVQual User Guide for Nvidia Networking Products”. The ports of the two cards are connected together. When I run network_diag, I was hitting this error. No info was found on the web so trying to get help on where to start. Any help on where to start is much appreciated.
12:01:30 [player 1] [temperature measurement] 65.0°C
Process Process-21:
File “/tmp/_MEIrpPr8p/utils/Accelerator.py”, line 149, in run_all_commands
rc, output = utils.run_command(
File “/tmp/_MEIrpPr8p/utils/utils.py”, line 686, in run_command
NvqualException(e, run_logger)
File “/tmp/_MEIrpPr8p/utils/utils.py”, line 561, in NvqualException
raise Exception(error)
Exception: From utils Couldn’t complete DPA action: [419225] flexio_func_pup_register 321 - Failed to find device function prdma_dev_post_receive_rpc in app ELF
Error while registering kernel: prdma_dev_post_receive_rpc()[419225] flexio_app_get 621 - No app match found for criteria name: ‘dpa_nvqual_app’, HW model ‘0x2’
[19:01:30:760160][419225][DOCA][ERR][dpa_nvqual_test.cpp:164][main] Failed to run DPA NVQual test: Failed to start DPA context: DOCA_ERROR_DRIVER
During handling of the above exception, another exception occurred:
File “/tmp/_MEIrpPr8p/utils/Accelerator.py”, line 189, in run
self.run_all_commands()
File “/tmp/_MEIrpPr8p/utils/Accelerator.py”, line 161, in run_all_commands
utils.NvqualException(f"run_commands failed: {e}", self.logger)
Exception: run_commands failed: From utils Couldn’t complete DPA action: [419225] flexio_func_pup_register 321 - Failed to find device function prdma_dev_post_receive_rpc in app ELF
File “multiprocessing/process.py”, line 315, in _bootstrap
File “multiprocessing/process.py”, line 108, in run
File “/tmp/_MEIrpPr8p/utils/NvqualObject.py”, line 201, in run_nvqualobject
nvqualobject.run()
File “/tmp/_MEIrpPr8p/utils/Accelerator.py”, line 192, in run
utils.NvqualException(f"run failed: {e}", self.logger)
Exception: run failed: run_commands failed: From utils Couldn’t complete DPA action: [419225] flexio_func_pup_register 321 - Failed to find device function prdma_dev_post_receive_rpc in app ELF
Hello hunle3,
Thank you for posting your inquiry on the NVIDIA Developer Forum - Infrastructure and Networking - Section.
This tools can only be used by NVIDIA Partners and OEMs, so for further information or assistance on how-to use the tool, please reach out to your NVIDIA Sales/Technical contact.
Thank you and regards,
~NVIDIA Networking Technical Support
