root@b3f869679ccf:~# deepstream-360d-app -c DeepStream360d_Release/samples/configs/deepstream-360d-app/source10_gpu0.txt
HostName : b3f869679ccf
** ERROR: main:351: Failed to set pipeline to PAUSED
Quitting
App run failed
Graphic Card: Titan X
Driver version: 140.79
CUDA Version: 10.0
HI,
May I know where you run from? remote terminal or from display desktop? if from remote terminal, Can you try
export DISPLAY=:0
sudo xhost +
first before you run deepstream-360d-app -c DeepStream360d_Release/samples/configs/deepstream-360d-app/source10_gpu0.txt within docker?
Right now, i am getting -
Quitting
ERROR from nvmsgbroker: Could not configure supporting library.
Debug info: gstnvmsgbroker.c(325): gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstNvMsgBroker:nvmsgbroker:
unable to connect to broker library
ERROR from nvmsgbroker: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5245): gst_base_sink_change_state (): /GstPipeline:pipeline/GstNvMsgBroker:nvmsgbroker:
