Continuing the discussion from Set ROI Tripview failed:
Hi @kesong ,
JPS latest: reference-workflow-and-resources_v1.1.0
I have tried to set our JETSON_IP in analytic_server_address in /opt/nvidia/jetson/services/vst/config/vst_config.json , and restart the service sudo systemctl restart jetson-vst, but I cannot set RoI and TRIPWIRE in `http://${JETSON_IP}:30080/vst/#/vst/live-streams for a selected stream.
Do you have any hint how to resolve this issue?
If I already had RoIs and TWs (using another tool to draw and get coordinates), where I can configure these params?
Can you have a try with Analytics API: Tripwire API Guide — Metropolis on Jetson documentation 0.1.0 documentation ?
Currently, my deployment has issue (I cannot access API endpoint ). When this issue has been fixed, I will try using APIs.
Hi. I have the same problem using a Jetson Orin Nano.
Followed all the install steps and also not sure what to do in order to fix it.
The latest release of JPS should works fine for ROI and tripwire: AI NVR — Metropolis on Jetson documentation 0.1.0 documentation
Many customer tested the feature. such as: How to modify values to improve accuracy of Tripwire and ROI? - Intelligent Video Analytics / Metropolis Microservices for Jetson - NVIDIA Developer Forums
