I tried to setup Jetpack 7.1 in a container on Thor, but failed. In container, when I run “apt show nvidia-jetpack”, it show me nothing, the package seems not being found. Can I setup Jetpack7.1 environment in a container?
AastaLLL
3
Which libraries do you need?
We already have containers for CUDA, PyTorch, so you don’t need to set up JetPack 7.1 within the container:
Related topics
| Jetpack 7.1 apt install issue nvidia-container | 12 | 1076 | January 15, 2026 | |
| Docker container Jetpack 7.x? | 6 | 421 | August 17, 2026 | |
| Docker Image for JetPack 7.1 | 5 | 1285 | February 4, 2026 | |
| Docker mirroring on JP7 | 2 | 155 | January 29, 2026 | |
| Jetson Thor: Containers does not see GPU | 5 | 446 | November 26, 2025 | |
| Docker container example that can use CUDA and Pytorch 2.5.0 with the host running Jetpack 6.1 | 7 | 1577 | December 26, 2024 | |
| PyTorch can't find CUDA inside JetPack 5.1 docker container | 2 | 1427 | March 24, 2023 | |
| Jetpack 5.0, pytorch container, container toolkit not found | 5 | 800 | April 14, 2022 | |
| WARNING: The NVIDIA Driver was not detected | 7 | 1288 | September 15, 2025 | |
| Nvidia L4T Jetpack vs Nvidia L4T pytorch | 1 | 625 | May 24, 2023 |
