Failed to start Load Kernel Modules on Xavier AGX - L4T 35.1 Real-Time Kernel
when i build the real time kernel (cross-compile) as described here, i get the error ‘Failed to start Load Kernel Modules’ and the device is stuck during boot with the message ’ A start job is running for End-user configuration after initial OEM installation (Debconf UI) (x min / no limit)
If I perform the same steps without applying the rt-patch the device boots successful. Did I miss something?
Did you configure the kernel correctly before compile? Also, since the patch causes modules to invalidate, did you also reinstall all modules?
Hi, have you tried JetPack 5.1 (L4T 35.2.1)?
Also, as mentioned by @linuxdev, check the kernel configuration before compiling.
Hi, please connect you AGX Xavier to the host PC via UART and post the log since booting.
