I updated the latest drivers (DriverVersion: 1.60.16216.0) and firmware successfully on one Node.
On the second node, I was able to update the driver using pnputil.exe command, however, I am not able to run the mst status.
I installed the latest WinMFT tool (WinMFT_x64_4_6_0_48.exe) on each node.
Please find the error below:
-E- MST devices:
No MST devices found
-E- Failed to start mst service (577): Windows cannot verify the digital signature for this file. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that might be malicious software from an unknown source.
I am running Windows Server 2016 and Windows Defender is running. I excluded the following path in Windows Defender but still the same issue:
