Same here for a different configuration.
OS: Ubuntu 24.04
GPU: NVIDIA GeForce RTX 4070 Laptop GPU
Tested Nvidia drivers: 575-open and 580-open (recommanded by ubuntu-drivers)
Secure boot: disabled
After purging every packages linked to nvidia, a new nvidia driver installation works the first boot, then the next boots fail.
The nouveau driver works (not so well, but at least booting does not fail).
I also tested blacklisting nouveau for systemd services, but booting still fails.
Working first boot logs for Nvidia:
$ cat 2026-01-09_15_04_boot_logs.log | grep nvidia
janv. 09 15:01:55 deputy-p60 kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
janv. 09 15:01:55 deputy-p60 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
janv. 09 15:01:55 deputy-p60 kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
janv. 09 15:01:55 deputy-p60 kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
janv. 09 15:01:56 deputy-p60 kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.95.05 Release Build (dvs-builder@U22-I3-B17-02-5) Tue Sep 23 09:42:01 UTC 2025
janv. 09 15:01:56 deputy-p60 kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
janv. 09 15:01:56 deputy-p60 kernel: Modules linked in: snd_soc_hda_codec mac80211(+) snd_hda_ext_core kvm snd_soc_core snd_hda_codec_hdmi nvidia_drm(OE+) libarc4 irqbypass snd_compress polyval_clmulni ac97_bus btusb polyval_generic snd_pcm_dmaengine ghash_clmulni_intel btrtl sha256_ssse3 processor_thermal_device_pci cmdlinepart uvcvideo sha1_ssse3 processor_thermal_device btintel snd_hda_intel aesni_intel processor_thermal_wt_hint spi_nor processor_thermal_rfim mei_pxp mei_hdcp btbcm videobuf2_vmalloc snd_intel_dspcfg nvidia_modeset(OE) iwlwifi crypto_simd uvc mtd ee1004 btmtk snd_intel_sdw_acpi processor_thermal_rapl intel_rapl_msr i915(+) nvidia(OE) videobuf2_memops snd_hda_codec mei_me cryptd intel_rapl_common i2c_i801 spi_intel_pci videobuf2_v4l2 rapl i2c_smbus drm_buddy processor_thermal_wt_req snd_hda_core cfg80211 bluetooth videobuf2_common intel_cstate spi_intel mxm_wmi mei i2c_mux drm_ttm_helper processor_thermal_power_floor snd_hwdep ttm processor_thermal_mbox drm_display_helper cec intel_pmc_core int3403_thermal
janv. 09 15:01:57 deputy-p60 systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: Verbose syslog connection opened
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: Now running with user ID 122 and group ID 124
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: Started (1753)
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for those files.
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: PID file unlocked.
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1752]: nvidia-persistenced failed to initialize. Check syslog for more details.
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: PID file closed.
janv. 09 15:01:57 deputy-p60 systemd[1]: nvidia-persistenced.service: Control process exited, code=exited, status=1/FAILURE
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1753]: Shutdown (1753)
janv. 09 15:01:57 deputy-p60 systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
janv. 09 15:01:57 deputy-p60 systemd[1]: Failed to start nvidia-persistenced.service - NVIDIA Persistence Daemon.
janv. 09 15:01:57 deputy-p60 kernel: [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 2
janv. 09 15:01:57 deputy-p60 kernel: nvidia 0000:01:00.0: [drm] Cannot find any crtc or sizes
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1870]: Verbose syslog connection opened
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1870]: Now running with user ID 122 and group ID 124
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1870]: Started (1870)
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1870]: device 0000:01:00.0 - registered
janv. 09 15:01:57 deputy-p60 nvidia-persistenced[1870]: Local RPC services initialized
janv. 09 15:01:57 deputy-p60 systemd[1]: Started nvidia-persistenced.service - NVIDIA Persistence Daemon.
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Applying OutputClass "nvidia" to /dev/dri/card2
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: loading driver: nvidia
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (==) Matched nvidia as autoconfigured driver 0
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) LoadModule: "nvidia"
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Module nvidia: vendor="NVIDIA Corporation"
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Applying OutputClass "nvidia" options to /dev/dri/card2
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Loading sub module "glxserver_nvidia"
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) LoadModule: "glxserver_nvidia"
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
janv. 09 15:01:58 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
janv. 09 15:01:59 deputy-p60 /usr/libexec/gdm-x-session[2070]: (WW) NVIDIA: '/var/run/nvidia-xdriver-3f32ae9f' Permission denied
janv. 09 15:01:59 deputy-p60 /usr/libexec/gdm-x-session[2070]: (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Applying OutputClass "nvidia" to /dev/dri/card2
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: loading driver: nvidia
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (==) Matched nvidia as autoconfigured driver 0
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) LoadModule: "nvidia"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/nvidia_drv.so
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Module nvidia: vendor="NVIDIA Corporation"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Applying OutputClass "nvidia" options to /dev/dri/card2
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Loading sub module "glxserver_nvidia"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) LoadModule: "glxserver_nvidia"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Loading /usr/lib/x86_64-linux-gnu/nvidia/xorg/libglxserver_nvidia.so
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (WW) NVIDIA: '/var/run/nvidia-xdriver-e223af8c' Permission denied
janv. 09 15:02:25 deputy-p60 /usr/libexec/gdm-x-session[2955]: (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
janv. 09 15:02:26 deputy-p60 systemd[2798]: Started app-gnome-nvidia\x2dsettings\x2dautostart-3531.scope - Application launched by gnome-session-binary.
janv. 09 15:03:55 deputy-p60 tracker-miner-f[3789]: Could not execute sparql: Unable to insert multiple values on single valued property `nfo:belongsToContainer' for resource file:///media/profchep/SHARED/Desktop/2026-01-09_14_59_systemctl_status_nvidia-persistenced_service.log (old_value: '622', new value: '1068')
janv. 09 15:03:59 deputy-p60 tracker-miner-f[3789]: Could not execute sparql: Unable to insert multiple values on single valued property `nfo:belongsToContainer' for resource file:///media/profchep/SHARED/Desktop/2026-01-09_15_02_systemctl_status_nvidia-persistenced_service.log (old_value: '622', new value: '1068')
systemctl status nvidia-persistencedfor working boot:
â—Ź nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-persistenced.service; static)
Active: active (running) since Fri 2026-01-09 15:01:57 PST; 1min 0s ago
Process: 1855 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, status=0/SUCCESS)
Main PID: 1870 (nvidia-persiste)
Tasks: 1 (limit: 37970)
Memory: 292.0K (peak: 1.0M)
CPU: 1ms
CGroup: /system.slice/nvidia-persistenced.service
└─1870 /usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose
Failing second boot logs for Nvidia:
$ cat fail_boot_logs.log | grep nvidia
janv. 09 20:13:40 deputy-p60 kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
janv. 09 20:13:40 deputy-p60 kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 509
janv. 09 20:13:40 deputy-p60 kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
janv. 09 20:13:40 deputy-p60 kernel: nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
janv. 09 20:13:40 deputy-p60 kernel: nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 580.95.05 Release Build (dvs-builder@U22-I3-B17-02-5) Tue Sep 23 09:42:01 UTC 2025
janv. 09 20:13:40 deputy-p60 kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
janv. 09 20:13:42 deputy-p60 systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: Verbose syslog connection opened
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: Now running with user ID 122 and group ID 124
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: Started (1244)
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for those files.
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: PID file unlocked.
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1243]: nvidia-persistenced failed to initialize. Check syslog for more details.
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: PID file closed.
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
janv. 09 20:13:42 deputy-p60 nvidia-persistenced[1244]: Shutdown (1244)
janv. 09 20:13:42 deputy-p60 systemd[1]: nvidia-persistenced.service: Control process exited, code=exited, status=1/FAILURE
janv. 09 20:13:42 deputy-p60 systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
janv. 09 20:13:42 deputy-p60 systemd[1]: Failed to start nvidia-persistenced.service - NVIDIA Persistence Daemon.
janv. 09 20:14:39 deputy-p60 (udev-worker)[558]: nvidia: Spawned process '/sbin/modprobe nvidia-drm' [920] is taking longer than 59s to complete
janv. 09 20:14:39 deputy-p60 systemd-udevd[513]: nvidia: Worker [558] processing SEQNUM=5298 is taking a long time
janv. 09 20:16:39 deputy-p60 (udev-worker)[558]: nvidia: Spawned process '/sbin/modprobe nvidia-drm' [920] timed out after 2min 59s, killing
janv. 09 20:16:39 deputy-p60 systemd-udevd[513]: nvidia: Worker [558] processing SEQNUM=5298 killed
janv. 09 20:16:39 deputy-p60 systemd-udevd[513]: nvidia: Worker [558] terminated by signal 9 (KILL).
janv. 09 20:17:42 deputy-p60 kernel: os_acquire_rwlock_write+0x31/0x50 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: portSyncRwLockAcquireWrite+0x10/0x40 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: rmapiLockAcquire+0x294/0x360 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: kgspInitRm_IMPL+0xcad/0x1680 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: RmInitAdapter+0xff2/0x1e40 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: rm_init_adapter+0xad/0xc0 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: nv_open_device+0x222/0xa80 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: nvidia_dev_get+0x68/0xd0 [nvidia]
janv. 09 20:17:42 deputy-p60 kernel: nvkms_open_gpu+0x4f/0x90 [nvidia_modeset]
janv. 09 20:17:42 deputy-p60 kernel: AllocateDevice+0x48/0x760 [nvidia_modeset]
janv. 09 20:17:42 deputy-p60 kernel: ? nv_drm_dev_load+0x112/0xd10 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: ? __pfx_nv_drm_event_callback+0x10/0x10 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: nv_drm_register_drm_device+0xb0/0x230 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: ? __pfx_nv_drm_register_drm_device+0x10/0x10 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: EnumerateGpus+0x150/0x160 [nvidia_modeset]
janv. 09 20:17:42 deputy-p60 kernel: ? nv_drm_probe_devices+0x66/0xa0 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: ? __pfx_nv_linux_drm_init+0x10/0x10 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: ? nv_drm_init+0x31/0x70 [nvidia_drm]
janv. 09 20:17:42 deputy-p60 kernel: ? nv_linux_drm_init+0xe/0xff0 [nvidia_drm]
systemctl status nvidia-persistencedfor failing boot:
Ă— nvidia-persistenced.service - NVIDIA Persistence Daemon
Active: failed (Result: exit-code) since Fri 2026-01-09 20:13:42 PST; 4min 59s ago
Process: 1243 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persistenced --no-persistence-mode --verbose (code=exited, status=1/FAILURE)
Process: 1246 ExecStopPost=/bin/rm -rf /var/run/nvidia-persistenced (code=exited, status=0/SUCCESS)
CPU: 4ms
Same dpkg –list | grep ii^.*nvidia for both:
ii libnvidia-cfg1-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-580 580.95.05-0ubuntu0.24.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-580:i386 580.95.05-0ubuntu0.24.04.2 i386 NVIDIA libcompute package
ii libnvidia-decode-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-580:i386 580.95.05-0ubuntu0.24.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.17-0ubuntu0~gpu24.04.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-egl-wayland1:i386 1:1.1.17-0ubuntu0~gpu24.04.1 i386 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-580:i386 580.95.05-0ubuntu0.24.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-580:i386 580.95.05-0ubuntu0.24.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-580:amd64 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-580:i386 580.95.05-0ubuntu0.24.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-580 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-580-open 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA DKMS package (open kernel module)
ii nvidia-driver-580-open 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA driver (open kernel) metapackage
ii nvidia-firmware-580-580.95.05 580.95.05-0ubuntu0.24.04.2 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-580 580.95.05-0ubuntu0.24.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-580-open 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.2 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu4 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-580 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-580 580.95.05-0ubuntu0.24.04.2 amd64 NVIDIA binary Xorg driver
