I patched imx477 driver on Xavier NX dev kit and flashed.
while rebooting, it displays “failed to start nvpmodel.service”.
Although it shows failed to start nvpmodel.service in booting, please check the system status. Power modes are listed in
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fpower_management_jetson_xavier.html%23wwpID0E0NO0HA
It is mode 3 by default and two CPUs are online. Please run sudo tegrastats to check if there are only two online CPUs.
I want to install four immx477 camera in p3509-0000-a00 platform.
I want to install four immx477 cameras in p3509-0000-a00 platform. so I modified DTSI files follows.
host1x {
vi@15c10000 {
num-channels = <4>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv3_imx477_vi_in0: endpoint {
status = “okay”;
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_out0>;
vi_port1: port@1 {
reg = <1>;
rbpcv3_imx477_vi_in1: endpoint {
status = “okay”;
port-index = <1>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_out1>;
vi_port2: port@2 {
reg = <0>;
rbpcv3_imx477_vi_in2: endpoint {
status = “okay”;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_out2>;
vi_port3: port@3 {
reg = <1>;
rbpcv3_imx477_vi_in3: endpoint {
status = “okay”;
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_out3>;
nvcsi@15a00000 {
num-channels = <4>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
status = "okay";
rbpcv3_imx477_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
status = "okay";
rbpcv3_imx477_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&rbpcv3_imx477_vi_in0>;
csi_chan1: channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
csi_chan1_port0: port@0 {
reg = <0>;
status = "okay";
rbpcv3_imx477_csi_in1: endpoint@2 {
port-index = <1>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_out1>;
csi_chan1_port1: port@1 {
reg = <1>;
status = "okay";
rbpcv3_imx477_csi_out1: endpoint@3 {
status = "okay";
remote-endpoint = <&rbpcv3_imx477_vi_in1>;
csi_chan2: channel@2 {
reg = <2>;
ports {
#size-cells = <0>;
csi_chan2_port0: port@0 {
reg = <0>;
status = "okay";
rbpcv3_imx477_csi_in2: endpoint@4 {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_out2>;
csi_chan2_port1: port@1 {
reg = <1>;
status = "okay";
rbpcv3_imx477_csi_out2: endpoint@5 {
status = "okay";
remote-endpoint = <&rbpcv3_imx477_vi_in2>;
csi_chan3: channel@3 {
reg = <3>;
ports {
#size-cells = <0>;
csi_chan3_port0: port@0 {
reg = <0>;
status = "okay";
rbpcv3_imx477_csi_in3: endpoint@6 {
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_out3>;
csi_chan3_port1: port@1 {
reg = <1>;
status = "okay";
rbpcv3_imx477_csi_out3: endpoint@7 {
remote-endpoint = <&rbpcv3_imx477_vi_in3>;
i2c@3180000 {
tca9548@77 {
i2c_0:i2c@0 {
imx477_cam0: rbpcv3_imx477_a@1a {
compatible = "ridgerun,imx477";
/* I2C device address */
reg = <0x1a>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "7.564";
physical_h = "5.476";
sensor_model = "imx477";
use_sensor_mode_id = "true";
mode0 { /* IMX477_MODE_4032X3040 */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "4032";
active_h = "3040";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
readout_orientation = "90";
line_length = "9024";
inherent_gain = "1";
mclk_multiplier = "80";
pix_clk_hz = "840000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "356"; /* 22x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30.0 fps */
step_framerate = "1";
default_framerate = "30000000"; /* 30.0 fps */
min_exp_time = "13"; /* us */
max_exp_time = "683709"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "2";
mode1 { /* IMX477_MODE_1920X1080 */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
max_framerate = "60000000"; /* 60.0 fps */
default_framerate = "60000000"; /* 60.0 fps */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_in0>;
i2c_1:i2c@1 {
imx477_cam1: rbpcv3_imx477_b@1a {
reg = <0x1a>;
devnode = "video1";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "4032";
active_h = "3040";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out1: endpoint {
port-index = <1>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_in1>;
i2c_2:i2c@2 {
imx477_cam2: rbpcv3_imx477_c@1a {
reg = <0x1a>;
devnode = "video2";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "4032";
active_h = "3040";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out2: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_in2>;
i2c_3: i2c@3 {
imx477_cam3: rbpcv3_imx477_d@1a {
reg = <0x1a>;
devnode = "video3";
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
active_w = "4032";
active_h = "3040";
gain_factor = "16";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out3: endpoint {
port-index = <3>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_in3>;
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
num_csi_lanes = <8>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
cam_module0: module0 {
badge = "jakku_front_RBP194";
position = "front";
orientation = "1";
status = "okay";
cam_module0_drivernode0: drivernode0 {
status = "okay";
pcl_id = "v4l2_sensor";
devname = "imx477 9-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/tca9548@77/i2c@0/rbpcv3_imx477_a@1a";
cam_module1: module1 {
badge = "jakku_rear_RBP194";
position = "rear";
orientation = "1";
status = "okay";
cam_module1_drivernode0: drivernode0 {
status = "okay";
devname = "imx477 10-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/tca9548@77/i2c@1/rbpcv3_imx477_b@1a";
cam_module2: module2 {
position = "front";
orientation = "1";
status = "okay";
cam_module2_drivernode0: drivernode0 {
status = "okay";
devname = "imx477 11-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/tca9548@77/i2c@2/rbpcv3_imx477_c@1a";
cam_module3: module3 {
position = "rear";
orientation = "1";
status = "okay";
cam_module3_drivernode0: drivernode0 {
status = "okay";
devname = "imx477 12-001a";
proc-device-tree = "/proc/device-tree/cam_i2cmux/tca9548@77/i2c@3/rbpcv3_imx477_d@1a";
#define CAM0_PWDN TEGRA194_MAIN_GPIO(P, 4)
#define CAM1_PWDN TEGRA194_AON_GPIO(CC, 3)
#define CAMERA_I2C_MUX_BUS(x) (0x1E + x)
/* camera control gpio definitions */
gpio@2200000 {
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_PWDN 0 CAM1_PWDN 0>;
label = “cam0-pwdn”, “cam1-pwdn”;
i2c@3180000 {
tca9548_77: tca9548@77{
compatible = "nxp,pca9548";
reg = <0x77>;
#size-cells = <0>;
/*vcc-supply = "NULL";*/
skip_mux_detect = "yes";
force_bus_start = <CAMERA_I2C_MUX_BUS(0)>;
i2c@0 {
reg = <0>;
i2c-mux,deselect-on-exit;
#size-cells = <0>;
pwdn-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
i2c@1 {
reg = <1>;
#size-cells = <0>;
pwdn-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
i2c@2 {
reg = <0>;
#size-cells = <0>;
i2c@3 {
reg = <1>;
#size-cells = <0>;
dmesg displays “pca954x 2-0077: vcc regualtor get failed, -19”
my cameras don’t use power from jetson kit.
Do you get the camera from our partners? We have camera partners:
Would need the vendor’s help. Would be great if you can provide information about the vendor.
