Description
Here is the content of a.cu:
$ cat a.cu
#include <NvInfer.h>
#include <NvInferPlugin.h>
int main() {
initLibNvInferPlugins(getLogger(), "");
nvinfer1::createInferBuilder(*getLogger());
I failed to static link with TensorRT 8.5.1.7 using CUDA 11.3.
$ /usr/local/cuda-11.3/bin/nvcc a.cu -I /usr/local/TensorRT-8.5.1.7/include -L /usr/local/TensorRT-8.5.1.7/lib -L /usr/local/cudnn-linux-x86_64-8.6.0.163_cuda11-archive/lib -L /usr/local/cuda-11.3/lib64 -lnvinfer_static -lnvinfer_plugin_static -lnvrtc -lcublas -lcublasLt -lcudnn -lnvptxcompiler_static -Xcompiler=-Wno-deprecated-declarations
/usr/bin/ld: /usr/local/TensorRT-8.5.1.7/lib/libnvinfer_static.a(hardware_information.cpp.1.o): in function `cask_trt::GpcSkyline::queryFromDevice(cask_trt::GpcSkyline&, cask_trt::SmModel const&, int)':
hardware_information.cpp:(.text+0xede): undefined reference to `cudaOccupancyMaxActiveClusters'
/usr/bin/ld: /usr/local/TensorRT-8.5.1.7/lib/libnvinfer_static.a(gemm_cublas.1.o): in function `myelin::exec::(anonymous namespace)::check_cublasLt_error(cublasStatus_t, std::string const&, myelin::util::errors_t&) [clone .part.224]':
gemm_cublas.cpp:(.text+0xec60): undefined reference to `cublasLtGetStatusName'
collect2: error: ld returned 1 exit status
I’m sure that TensorRT 8.0/8.2/8.4 + CUDA 10.2/11.3 is OK, and TensorRT 8.5 + CUDA 10.2/11.8 is also OK.
But I shouldn’t compile the software using CUDA 11.8. The reason is that my customers’ environment is CUDA 11.0 ~ 11.4 and they will get ./a.out: symbol lookup error: ./a.out: undefined symbol: cublasLtGetStatusName, version libcublasLt.so.11
if I link with the cuBLAS in CUDA 11.8.
Environment
TensorRT Version: 8.5.1.7
GPU Type: NVIDIA GeForce RTX 3080
Nvidia Driver Version: 528.02
CUDA Version: 11.3
CUDNN Version: 8.6.0.163
Operating System + Version: WSL, Ubuntu 22.04.1 LTS
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
$ cat a.cu
int main() {
Steps To Reproduce
- Install CUDA, cuDNN, TensorRT
