Hello
I’m trying to host h264/h265 GPU encoded rtsp from my inference pipeline using nvv4l2{codec}enc/nv{codec}enc with gstreamer but unable to launch stream
so far only x264enc/x265enc plugin based pipeline is working our case
On RTX A4000, we would suggest use Video Codec SDK. If you would like to have the gstreamer plugins, please install DeepStream SDK and replace nvvidconv with nvvideoconvert plugins. The nvvidconv plugin is supported only on Jetson platforms.
#./a.out
RTSP server is running at rtsp://127.0.0.1:8554/test
output is stuck at that but i port forward 8554 and access from my server, got this
GST_DEBUG=3 ./a.out
0:00:08.403444134 17336 0x7fce8c000b90 ERROR rtspclient rtsp-client.c:5168:handle_tunnel: client 0x557551465600: no tunnelid provided
