Frames will be saved in frame
Creating Pipeline
Creating streamux
.......... 1
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Atleast one of the sources is live
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
1 : rtsp://127.0.0.1:554/live/ch
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_ProcessPast not implemented
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: TensorRT was linked against cuDNN 8.1.0 but loaded cuDNN 8.0.4
WARNING: ../nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.3.0 but loaded cuBLAS/cuBLAS LT 11.2.1
0:00:13.487786227 10402 0x25f1c10 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1702> [UID = 1]: deserialized trt engine from :/home/Download/deepstream_python_apps/apps/deepstream-imagedata-multistream/model_trt.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_0 3x640x640
1 OUTPUT kFLOAT output_0 8400x15
0:00:13.487903092 10402 0x25f1c10 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1806> [UID = 1]: Use deserialized engine model: /home/Download/deepstream_python_apps/apps/deepstream-imagedata-multistream/model_trt.engine
0:00:13.489660223 10402 0x25f1c10 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:config_infer_primary_yoloV5.txt sucessfully
Decodebin child added: source
**PERF: {'stream0': 0.0}
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
KLT Tracker Init
ERROR: nvdsinfer_context_impl.cpp:1573 Failed to synchronize on cuda copy-coplete-event, cuda err_no:700, err_str:cudaErrorIllegalAddress
0:00:18.318243659 10402 0xf628f0 WARN nvinfer gstnvinfer.cpp:2021:gst_nvinfer_output_loop:<primary-inference> error: Failed to dequeue output from inferencing. NvDsInferContext error: NVDSINFER_CUDA_ERROR
0:00:18.318454891 10402 0xf628f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::releaseBatchOutput() <nvdsinfer_context_impl.cpp:1607> [UID = 1]: Tried to release an outputBatchID which is already with the context
Cuda failure: status=700 in CreateTextureObj at line 2902
nvbufsurftransform.cpp:2703: => Transformation Failed -2
Then there is no problem at all. I have tested more than 10 rtsp channels. There are some small problems, but they have been solved so far. After adding tracking, it will not work, but I need tracking to improve the missing boxes of infer.
This is my blog. I don’t understand how 6.1 tracker integrates 5.1 and solves my bug. If there is more information on this, can you provide me with some information to improve my notes?
Oh, I can see that deepstream 5.1 divides so into four parts, while deepstream 6.1 divides YML into four parts. The tracker item and code I configured above are based on the modification of deepstream 5.1, and the default parameters of YML are directly commented out. As for this bug, I think we can study it again. Thank you for your answer
