My scenario of a pipeline is below.
gst-launch-1.0 -e -v rtmpsrc location='rtmp://192.168.0.11/live/s2' ! flvdemux name=dem \
dem.video ! queue ! h264parse ! omxh264dec ! nvvidconv ! capsfilter ! nvoverlaysink \
dem.audio ! queue ! fakesink
And I tested to change a capsfilter element dynamically using python with my same scenario.
This is my test example below.
Dynamic Pipeline Example.
rtmpsrc -> ... -> videosink.
import sys
import gi
gi.require_version('Gst', '1.0')
gi.require_version('GLib', '2.0')
gi.require_version('GObject', '2.0')
from gi.repository import GObject, Gst, GLib
Launcher.
class Launcher:
def __init__(self, args):
self.pipeline = Gst.Pipeline.new()
self.src = Gst.ElementFactory.make("rtmpsrc")
self.demux = Gst.ElementFactory.make("flvdemux")
self.demux_v_que = Gst.ElementFactory.make("queue")
self.h264parse = Gst.ElementFactory.make("h264parse")
self.vdec = Gst.ElementFactory.make("omxh264dec")
self.vconv = Gst.ElementFactory.make("nvvidconv")
self.caps = Gst.ElementFactory.make("capsfilter")
self.vsink = Gst.ElementFactory.make("nvoverlaysink")
# self.vdec = Gst.ElementFactory.make("avdec_h264")
# self.vconv = Gst.ElementFactory.make("videoscale")
# self.caps = Gst.ElementFactory.make("capsfilter")
# self.vsink = Gst.ElementFactory.make("glimagesink")
self.demux_a_que = Gst.ElementFactory.make("queue")
self.asink = Gst.ElementFactory.make("fakesink")
self.pipeline.add(self.src)
self.pipeline.add(self.demux)
self.pipeline.add(self.demux_v_que)
self.pipeline.add(self.h264parse)
self.pipeline.add(self.vdec)
self.pipeline.add(self.vconv)
self.pipeline.add(self.caps)
self.pipeline.add(self.vsink)
self.pipeline.add(self.demux_a_que)
self.pipeline.add(self.asink)
# take the commandline argument and ensure that it is a uri
if Gst.uri_is_valid(args[1]):
uri = args[1]
else:
uri = Gst.filename_to_uri(args[1])
self.src.set_property('location', uri)
# self.vdec.set_property('disable-dpb', True)
# capsprop = Gst.Caps.from_string("video/x-raw(memory:NVMM)")
# self.caps.set_property("caps", capsprop)
self.src.link(self.demux)
self.demux.connect("pad-added", self.pad_added_handler)
self.demux_v_que.link(self.h264parse)
self.h264parse.link(self.vdec)
self.vdec.link(self.vconv)
self.vconv.link(self.caps)
self.caps.link(self.vsink)
self.demux_a_que.link(self.asink)
# create and event loop and feed gstreamer bus mesages to it
self.loop = GObject.MainLoop()
GLib.timeout_add_seconds(5, self.timeout_cb)
bus = self.pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", self.on_message)
# start play back and listed to events
self.pipeline.set_state(Gst.State.PLAYING)
try:
self.loop.run()
except:
pass
# cleanup
self.pipeline.set_state(Gst.State.NULL)
def pad_added_handler(self, src, new_pad):
print("Received new pad '%s' from '%s':" % (new_pad.get_name(),
src.get_name()))
# If our converter is already linked, we have nothing to do here
if new_pad.is_linked():
print("We are already linked. Ignoring.")
return
# Check the new pad's type
new_pad_type = new_pad.query_caps(None).to_string()
if new_pad_type.startswith("audio"):
print(" It has type '%s' which is audio." %
new_pad_type)
new_pad.link(self.demux_a_que.get_static_pad("sink"))
elif new_pad_type.startswith("video"):
print(" It has type '%s' which is video." %
new_pad_type)
new_pad.link(self.demux_v_que.get_static_pad("sink"))
else:
print("error!")
return
def on_message(self, bus, message):
t = message.type
if t == Gst.MessageType.EOS:
sys.stdout.write("End-of-stream\n")
self.loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
sys.stderr.write("Error: %s: %s\n" % (err, debug))
self.loop.quit()
return True
def probe_cb(self, pad, info):
print("called probe_cb")
self.caps.set_state(Gst.State.NULL)
self.pipeline.remove(self.caps)
self.caps = Gst.ElementFactory.make('capsfilter')
# "video/x-raw(memory:NVMM), width=480, height=270")
self.caps.sync_state_with_parent()
self.caps.set_state(Gst.State.PLAYING)
return Gst.PadProbeReturn.REMOVE
def timeout_cb(self):
print("called timeout_cb")
srcpad = self.src.get_static_pad('src')
srcpad.add_probe(Gst.PadProbeType.IDLE, self.probe_cb)
return True
def main(args):
if len(args) != 2:
sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
sys.exit(1)
GObject.threads_init()
Gst.init(None)
Launcher(args)
if __name__ == '__main__':
sys.exit(main(sys.argv))
This example is failed when a probe_cb function is called!
There are two kinds of errors.
First, a process terminated.
An error messages is below.
# GST_DEBUG=3 python ./rtmpsrc_vsink.py rtmp://192.168.0.11/live/s2
0:00:00.044121315 869 0xb99f20 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /root/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:00.341570323 869 0x99a280 WARN flvdemux gstflvdemux.c:627:gst_flv_demux_parse_tag_script:<flvdemux0> failed reading a tag, skipping
Received new pad 'audio' from 'flvdemux0':
It has type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, rate=(int)44100, channels=(int)2, codec_data=(buffer)1208' which is audio.
Received new pad 'video' from 'flvdemux0':
It has type 'video/x-h264, stream-format=(string)avc, pixel-aspect-ratio=(fraction)1/1, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, codec_data=(buffer)01424028ffe1000b6742402895a01e0089f95001000468ce3c80' which is video.
0:00:00.408511751 869 0x99a190 FIXME videodecoder gstvideodecoder.c:946:gst_video_decoder_drain_out:<omxh264dec-omxh264dec0> Sub-class should implement drain()
NvMMLiteOpen : Block : BlockType = 261
TVMR: NvMMLiteTVMRDecBlockOpen: 7647: NvMMLiteBlockOpen
NvMMLiteBlockCreate : Block : BlockType = 261
TVMR: cbBeginSequence: 1179: BeginSequence 1920x1088, bVPR = 0
TVMR: LowCorner Frequency = 180000
TVMR: cbBeginSequence: 1529: DecodeBuffers = 5, pnvsi->eCodec = 4, codec = 0
TVMR: cbBeginSequence: 1600: Display Resolution : (1920x1080)
TVMR: cbBeginSequence: 1601: Display Aspect Ratio : (1920x1080)
TVMR: cbBeginSequence: 1669: ColorFormat : 5
TVMR: cbBeginSequence:1683 ColorSpace = NvColorSpace_YCbCr601
TVMR: cbBeginSequence: 1809: SurfaceLayout = 3
TVMR: cbBeginSequence: 1902: NumOfSurfaces = 12, InteraceStream = 0, InterlaceEnabled = 0, bSecure = 0, MVC = 0 Semiplanar = 1, bReinit = 1, BitDepthForSurface = 8 LumaBitDepth = 8, ChromaBitDepth = 8, ChromaFormat = 5
TVMR: cbBeginSequence: 1904: BeginSequence ColorPrimaries = 2, TransferCharacteristics = 2, MatrixCoefficients = 2
Allocating new output: 1920x1088 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3464: Send OMX_EventPortSettingsChanged : nFrameWidth = 1920, nFrameHeight = 1088
TVMR: FrameRate = 33
TVMR: NVDEC LowCorner Freq = (198000 * 1024)
---> TVMR: Video-conferencing detected !!!!!!!!!
TVMR: FrameRate = 29.992562
called timeout_cb
called probe_cb
0:00:05.109768786 869 0x99c2d0 WARN omxvideodec gstomxvideodec.c:2904:gst_omx_video_dec_loop:<omxh264dec-omxh264dec0> error: Internal data stream error.
0:00:05.109920591 869 0x99c2d0 WARN omxvideodec gstomxvideodec.c:2904:gst_omx_video_dec_loop:<omxh264dec-omxh264dec0> error: stream stopped, reason not-linked
Error: gst-stream-error-quark: Internal data stream error. (1): /dvs/git/dirty/git-master_linux/external/gstreamer/gst-omx/omx/gstomxvideodec.c(2904): gst_omx_video_dec_loop (): /GstPipeline:pipeline0/GstOMXH264Dec-omxh264dec:omxh264dec-omxh264dec0:
TVMR: TVMRFrameStatusReporting: 6132: Closing TVMR Frame Status Thread -------------
TVMR: TVMRVPRFloorSizeSettingThread: 5942: Closing TVMRVPRFloorSizeSettingThread -------------
TVMR: TVMRFrameDelivery: 5982: Closing TVMR Frame Delivery Thread -------------
TVMR: NvMMLiteTVMRDecBlockClose: 7815: Done
Second, a process blocked.
0:00:00.043790894 830 0xb99f20 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /root/.config:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:00.247391457 830 0x99a280 WARN flvdemux gstflvdemux.c:627:gst_flv_demux_parse_tag_script:<flvdemux0> failed reading a tag, skipping
0:00:00.257271286 830 0x99a190 FIXME videodecoder gstvideodecoder.c:946:gst_video_decoder_drain_out:<omxh264dec-omxh264dec0> Sub-class should implement drain()
TVMR: FrameRate = 29.970090
called timeout_cb
called probe_cb
called timeout_cb
called probe_cb
called timeout_cb
called probe_cb
I want to know what caused the problem and how to fix it.
Environment:
Jetson TX2, Jetpack 3.2.1, Gstreamer version 1.8.3
