Failed to update the kernel and the kernel ids were inconsistent
We used AGX Xavier industrial. Module and used SDK manager to update Jetpack4.5.1 kernel, prompting model error and kernel update failure.I used the LSUSB command to check the kernel ID of the failure message is 0955:7919.
The correct kernel ID number is 0955:7019.
Could you please help to confirm what the problem is?thank you
Hi aaron.ge,
The AGX Xavier industrial was supported from JetPack4.6.
It can’t work with JetPack 4.5.1.
Please try with JetPack 4.6 again.
