Failing compilation with clang
Greetings! I am using clang19 to compile a cuda program. I followed cuda toolkit installation steps.
nvcc version is 12.2.2; gpu arch = Quadro M620; clang19; gcc 11.
Compile command: clang+±19 testclang.cu -o testclang --cuda-gpu-arch=sm_61 -L/usr/local/cuda
And then these errors line:
/usr/bin/ld: /tmp/testclang-be4996.o: in function __device_stub__hello_kernel()': testclang.cu:(.text+0x19): undefined reference to __cudaPopCallConfiguration’
/usr/bin/ld: testclang.cu:(.text+0x65): undefined reference to cudaLaunchKernel' /usr/bin/ld: /tmp/testclang-be4996.o: in function main’:
testclang.cu:(.text+0xd6): undefined reference to __cudaPushCallConfiguration' /usr/bin/ld: testclang.cu:(.text+0xe5): undefined reference to cudaDeviceSynchronize’
/usr/bin/ld: /tmp/testclang-be4996.o: in function __cuda_register_globals': testclang.cu:(.text+0x144): undefined reference to __cudaRegisterFunction’
/usr/bin/ld: /tmp/testclang-be4996.o: in function __cuda_module_ctor': testclang.cu:(.text+0x159): undefined reference to __cudaRegisterFatBinary’
/usr/bin/ld: testclang.cu:(.text+0x175): undefined reference to __cudaRegisterFatBinaryEnd' /usr/bin/ld: /tmp/testclang-be4996.o: in function __cuda_module_dtor’:
testclang.cu:(.text+0x199): undefined reference to `__cudaUnregisterFatBinary’
clang+±19: error: linker command failed with exit code 1 (use -v to see invocation)
Cuda program:
include <stdio.h>
include <cuda.h>"
global void hello_kernel() {
printf(“Hello, CUDA from GPU!\n”);
int main() {
hello_kernel<<<1, 1>>>();
cudaDeviceSynchronize();
printf(“Hello, CUDA from CPU!\n”);
return 0;
Any hint will be much appreciated. Thanks.
Unsure how relevant it is, given the errors, but according to the Installation Guide for 12.2.2. the only certified Clang versions are 7.x to 16.
I solved it: clang+±19 … -L/usr/local/cuda -lcudart_static -ldl -lrt -pthread
