I am trying to save an I420 image (after it gets nvconverted from UYVY) using a gstreamer pipeline.
I have tried the below pipelines:
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! 'video/x-raw, format=(string)UYVY, width=(int)3840, height=(int)2160' ! nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)I420' ! filesink location=test.I420
It resulted in a 1kb file being saved.
Then after reading https://devtalk.nvidia.com/default/topic/916204/jetson-tx1/saving-csi-nvcamera-raw-frames-to-file-using-gstreamer-/
I tried
gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=1 ! 'video/x-raw(memory:NVMM), format=(string)UYVY, width=(int)3840, height=(int)2160' ! nvvidconv ! 'video/x-raw, format=(string)I420' ! filesink location=test.I420
But I got the following error:
WARNING: erroneous pipeline: could not link v4l2src0 to nvvconv0, v4l2src0 can't handle caps video/x-raw(memory:NVMM), format=(string)I420, width=(int)3840, height=(int)2160
I would like to know what would be a correct pipeline for saving an x-raw I420 image using nvvidconv.
Thanks for any help!
