I am trying to build a refittable engine from the resnet50 uff model provided in the TensorRT samples. However, when I set builder.refittable = True
. The model fails to build and I get the following error:
root@44e0dfd5ebc5:/workspace/tensorrt/samples/python/introductory_parser_samples# python3 uff_resnet50.py
python3: …/builder/cudnnBuilderGraphNodes.h:217: void nvinfer1::builder::fromSymbolicHelper(nvinfer1::builder::Graph&, Node_&) [with Node_ = nvinfer1::builder::RefittableNodeT<(nvinfer1::builder::NodeType)3, nvinfer1::PoolingParameters, true, 479>]: Assertion `node.expr != nullptr && “node does not have an expression to flip from”’ failed.
Aborted (core dumped)
Code for resnet50 UFF model:
def build_engine_uff(model_file):
# You can set the logger severity higher to suppress messages (or lower to display more messages).
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.UffParser() as parser,builder.create_builder_config() as builder_config:
# Workspace size is the maximum amount of memory available to the builder while building an engine.
# It should generally be set as high as possible.
builder.max_workspace_size = common.GiB(1)
# We need to manually register the input and output nodes for UFF.
parser.register_input(ModelData.INPUT_NAME, ModelData.INPUT_SHAPE)
parser.register_output(ModelData.OUTPUT_NAME)
# Load the UFF model and parse it in order to populate the TensorRT network.
parser.parse(model_file, network)
# Build and return an engine.
return builder.build_cuda_engine(network)
However, when I tried the same with the resnet50 onnx example the engine builds with no errors.
Code for ONNX model
def build_engine_onnx(model_file):
with trt.Builder(TRT_LOGGER) as builder,builder.create_builder_config() as builder_config, builder.create_network(common.EXPLICIT_BATCH) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.refittable=True
# Load the Onnx model and parse it in order to populate the TensorRT network.
print(os.path.exists(model_file))
with open(model_file, 'rb') as model:
x = model.read()
if not parser.parse(x):
print ('ERROR: Failed to parse the ONNX file.')
for error in range(parser.num_errors):
print (parser.get_error(error))
return None
