Description
Using trtexec.exe to create a trt.engine file from the attached dynamic onnx file with batch > 1 fails with the following error:
ERROR:
[E] Error[4]: [graphShapeAnalyzer.cpp::nvinfer1::builder::`anonymous-namespace’::ShapeNodeRemover::analyzeShapes::1872] Error Code 4: Miscellaneous (IISelectLayer /Where: broadcast dimensions must be conformable)
Environment
GPU Type: NVIDIA RTX A3000 Laptop GPU
Nvidia Driver Version: 511.65
CUDA Version: 11.6, V11.6.124
CUDNN Version: 8.4.1
Operating System + Version: Windows 10
Python Version (if applicable): 3.8.8
TensorRT Version (if applicable): 8.5.1.7
PyTorch Version (if applicable): 1.13.1+cu117
Baremetal or Container (if container which image + tag): Baremetal
Relevant Files - You will find the onnx file, the plugin dll and the c++ code that was used to build the dll in the following link:
Steps To Reproduce
I ran trtexec.exe with the onnx model to create a trt.engine file whith batch=1, and the trt.engine file was created successfully.
This is the command I used:
trtexec.exe --onnx=model.onnx --saveEngine=model.trt.engine --plugins=Plugin.dll --minShapes=input:1x3x1024x1024 --optShapes=input:1x3x1024x1024 --maxShapes=input:1x3x1024x1024 –verbose -
I replaced the batch number 1 with 10, and ran the following command:
trtexec.exe --onnx=model.onnx --saveEngine=model.trt.engine --plugins=Plugin.dll --minShapes=input:10x3x1024x1024 --optShapes=input:10x3x1024x1024 --maxShapes=input:10x3x1024x1024 –verbose
The creation of trt.engine file failed with the following error:
[E] Error[4]: [graphShapeAnalyzer.cpp::nvinfer1::builder::`anonymous-namespace’::ShapeNodeRemover::analyzeShapes::1872] Error Code 4: Miscellaneous (IISelectLayer /Where: broadcast dimensions must be conformable).
Thank you!
Tanya Z.
