Failure in isaac_ros_gxf during build of isaac_ros_nitros
Isaac Sim Version: 4.5.0
Ubuntu 22.04
hello.
When building the following four in a local environment, I get a failure on isaac_ros_gxf for isaac_ros_nitros.
Build target:
Command:
colcon build --symlink-install
Error message:
--- stderr: isaac_ros_gxf
CMake Error at CMakeLists.txt:61 (set_property):
 Error evaluating generator expression:
 $<INSTALL_PREFIX>
  INSTALL_PREFIX is a marker for install(EXPORT) only.  It should never be
 evaluated.
@hirayaka Are you building it inside a docker container? Could you please share you complete steps to reproduce this issue?
I built it outside of docker because there was no isaac_manipulator_pick_and_place within docker that I wanted to use.
I followed these steps
  1. clone the build target from git.
  2. run command
@hirayaka please follow this tutorial Tutorial for Isaac Manipulator Reference Workflows with Isaac Sim — isaac_ros_docs documentation to run Isaac Manipulator with Isaac Sim. The docker container also provides necessary dependencies.
Hello!
Best regards,
